Wires were cut - what were they for?? Help
1 Post
Car: 1984 firebird se
Axle/Gears: 373
An 84 Firebird SE - was a 305 Carb - 700 R4. I am working on rust repair. I removed the plastic piece from the passenger front wheel well and found all of these wires cut.. Prior to tearing the car apart, I had the car running, drivable, lights worked, etc. I have a shop manual for this car. However, I cannot quite grasp what these were for. They appear to go into a computer box (s) under the plastic on the passenger side. I am updating the motor to a 5.7, tranny will remain the same although it is updated. Any and all thoughts or help will be greatly appreciated. thx byron
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Wires were cut - what were they for?? Help
ECM harness to the ECM under the pass side hush panel. I 'assume' your car was successfully converted to mech carb/mech distributor?
The remainder of the harness can be pulled through and the ECM removed. It's no longer doing anything.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Yes, the part that is missing would normally go up through the rear of the wheel well and behind the strut tower and then over to the engine via the same black conduit.
Looks like they may have cut it and let the rest fall inside.
1 Post
Axle/Gears: 373
Bad n scorpner.. Thanks for your feedback. Much appreciated. Thx byron
1 Post
Axle/Gears: 373
Naf.. I apologize for the incorrect name. I would like to blame the iPad.. my fault. Thx b
db057
08-11-2015 10:11 PM
