1990 vs 1991 camaro body harness....
Car: 1991 Z28
Engine: 383
Transmission: TH350
Anyone know if there is a difference in the way a 1990 Iroc body harness and a 1991 Z28 body harness would be pinned at the bulk head connector? I have found the 1990 bulk head connector pin diagram but cannot find the 1991. Any help is greatly appreciated.
Thanks,
Adam
Thanks,
Adam
Re: 1990 vs 1991 camaro body harness....
These are from the 91 service manual,
Here is the C207 Dash-to-ECM connection: ( should be the same from 90-92 - double check to be sure !! )
1990 - 1992 C207
PIN Color From / To (Notes)
A Brown ( TBI )
B* Pnk (Red) INJ1 TBI (TBI)
B* Pnk/Blk INJ1 (V6 / TPI)
C Brn/Wht ECM / CE Light
D Grey Speed ECM to Cluster (Not with TBI)
E Wht/Blk ALDL (pin B) / ECM (test)
F Pnk/Blk ECM fuse / ECM
G* Pink/Blk (white) INJ2 TBI (TBI)
G* Pnk/Blk (INJ2 V6 TPI)
H* Tan/Blk ALDL / TCC-ECM (auto)
H* Tan/Blk ALDL / Upshift (stick)
J Org ALDL (pin E) / ECM
K Brown ECM / Buffer (Only TBI)
L Drk Blue Vats to ECM
M Org Interior Lights
N Org/Blk ECM / P/N switch
P Red Speed Sensor (Not with TBI)
R Ppl/Wht Crank Fuse / Cold Start-(only TBI)
Good Luck !
1990 - 1992 C207
A Brown ( TBI )
Good Luck !
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
sailtexas186548
02-29-2016 08:40 AM
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
