Firebird Pop Up Headlight / Motor / Switch Question...
Old 09-03-2015, 12:12 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
So, what tells the motor to stop once light is open / closed?
Something in the switch or the motor?
I'm assuming it's not constantly trying to open / close the light, or it would burn up the motor...
I want to use other buttons & change location for headlight switch...
Thanks,
Rafael
Old 09-03-2015, 06:00 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: Firebird Pop Up Headlight / Motor / Switch Question...
For the two wire style it measures current to determine when to stop. So it just keeps going until it hits the stop, then the current spikes which is detected by the chip inside the control unit. This is why when the bushings wear out, it keeps spinning even if it's all the way at the top of the travel.
Old 09-03-2015, 06:10 PM
luvofjah's Avatar
Is the headlight switch in the dash the "control unit"?
Old 09-03-2015, 06:33 PM
someone972's Avatar
Engine: 5.7L TPI
Nope, there's a box in the engine bay. It's attached to the firewall on the driver's side next to the fuel pump relay. Has two plugs, one with four and one with five or six terminals.
Old 09-03-2015, 06:50 PM
luvofjah's Avatar
So I can use regular on /off switches (with relay).
Moving them to center console...
Old 09-03-2015, 06:59 PM
someone972's Avatar
Engine: 5.7L TPI
As long as you get the wiring right, I don't see why not. My service manual isn't around right now, so I can't double check against the wiring diagram. Do you plan on keeping the parking light function working, or always have the headlights come up when the parking lights are on?
Old 09-03-2015, 07:02 PM
luvofjah's Avatar
Two switches, one for the parking lights and another for the headlights. I have the wiring figured out.
Old 09-03-2015, 07:08 PM
someone972's Avatar
Engine: 5.7L TPI
Should work then. There's no fancy electronics in the switch, just a set of contacts. In case you aren't aware, the headlights will not go down as long as the parking light circuit (brown wire?) is getting power, even if the headlight wire (yellow?) is no longer receiving power. Probably also have to be powering the brown wire whenever you're powering the headlights on wire. Going from memory here, but figured I'd mention it in case you didn't account for it yet.
Ghettobird52
12-29-2023 08:23 AM
1992 Trans Am
05-10-2023 07:19 PM
jhawkeye
05-25-2022 06:33 PM
BRoss99
12-07-2020 06:50 PM
pigpete
Exterior Parts Wanted
08-15-2015 07:56 AM
Quick Reply: Firebird Pop Up Headlight / Motor / Switch Question...
