t5 swap questions
t5 swap questions
I swapped out a 350 turbo for a T5. So i need a little help with wiring. If i remember correctly the purple and yellow wires that were going to the switch on the shifter (NSS correct?) need to be ran to the clutch pedal switch? Also, which 2 wires do i need to run to the switch on the t5 for the back up lights to function?
Thanks for the help.
Received 1,666 Likes
Re: t5 swap questions
Correct on the starter safety switch.
Backup light wires are blue and green.
89RustangRemover
11-12-2001 09:14 PM
88'camaro305TBI
10-08-2001 09:39 AM
