Convert mechanical dizzy to CC
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
On the mechanical dizzy. If you lock out the vac advance and mechanical advance, can you just change the module with a 7 pin HEI for computer control?
Or is the pickup in the non-cc distributors different?
-- Joe
-- Joe
Received 1,666 Likes
Re: Convert mechanical dizzy to CC
AFAIK the pickup is the same. (functionally anyway... may not be "the same" as in, part #) Just makes a pulse as the starwheel teeth pass through line-up.
BOTTLEDZ28
06-27-2016 09:50 PM
