Toggle Switch To Coil
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
ok, i have no juice to the coil but the engine cranks well. i have not yet replaced the ignition switch BUT i'm considering just running 12v to the coil via a toggle switch which would also act as an anti-theft device. has anyone done this on an 86 Trans am? which contact do i put 12v to? oh, and it would also be a good test. if it starts then it's most likely my ignition switch.
THANKS!
THANKS!
Re: Toggle Switch To Coil
THANKS!
THANKS!
Building a full on race car with a custom dashboard that uses all toggle switches for all functions ? Sure , toggles are used in that application all the time .
"Fixing" a street driven car by hacking up the wiring with a toggle switch rather than just doing it right the first time and being done with it ? Sorry , but , this is exactly the kinds of hackjobs that does the image of our cars no favors whatsoever .
Not trying to be a dick here , much , just trying to drive home the point of your car's wiring being kinda like virginity , it's only pure till it ain't , and once that first wire is cut , it's ALL downhill from there , it'll be out drinkin and smokin and whorein in no time flat !
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
well, using a toggle will accomplish three things:
#1. it will isolate the ignition switch as the culprit which i can then change at my leisure.
#2. it will get this car RUNNING so that i can then start working on it in earnest.
#3. it will be a theft deterrent device.
so, again: has anyone done this and to which wire on the coil should i $hit-rig the toggle?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
We Have Ignition
There is a pink wire coming out of the ignition switch.
That is the one that will get one side of the toggle switch.
The other side of the toggle switch will go to the 10 AWG red wire going into the ignition switch.
Use 10 AWG wire for your new ones.
Happy Racing !
Don’t Fuss Paintin’ Your Back Bumper, Cause B4 The Race Is Over I’m Gonna’ Be Pushing You Out Of The Way
Happy Racing !
Car: 86 WS6 5sp TA
Transmission: 5sp
Axle/Gears: posi
that's what i needed to know. THANKS! i've been waiting for it to cool down a bit but i'll get under there later today IF the daily T-storms hold off. i can't wait for winter...
propaintball96
04-12-2016 01:30 PM
