Does anybody know what this is?
Old 12-03-2016, 04:19 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
looking for diagram or what the white and tan wires go too.
Old 12-03-2016, 06:01 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Axle/Gears: Stock / 4:11 Moser 9"
Re: Does anybody know what this is?
Tan with white line wire should be for the fuel pump.
Old 12-03-2016, 09:02 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
It'd help to know the year and model of the car, along with where the harness in question is located.
Old 12-04-2016, 11:14 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Body harness connector behind the kick panel on all 82-85 Camaros. (C200) It's got the courtesy connector (small plug) and the rear tail light/tank wiring (large plug)
Old 12-04-2016, 05:57 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Thank you
Old 12-20-2016, 08:03 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Is aftermarket fuel guage wired to pink wire? Whats location of fuel guage wire in 85?
Old 12-21-2016, 12:29 AM
John in RI's Avatar
The fuel tank "level" indicator wire is the PINK wire on the same plug that you pictured above. ( C200 ).
Old 12-21-2016, 11:04 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
perfect. Thats what i thought just wanted to make sure. Thanks again
Old 12-21-2016, 01:05 PM
John in RI's Avatar
No Problem !
