brake light switch problem
Old 01-28-2017, 07:49 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
recently converted from t5 to t56. when I step on the brakes I have no brake lights. the lights work when turned on. when driving I hear a clicking sound from the pedal area. I may have disconnected or damaged something under there. any ideas?
Old 01-29-2017, 12:39 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: brake light switch problem
This has nothing to do with the transmission, so rule all of that out. Most likely you broke/cracked the brake pedal switch OR you didn't reconnect it. It's an easy fix and the brake switches are cheap, maybe $10-15. Its just ridiculous how easy they are to break or crack. I had the same discovery when I put the transmission and pedals back into my project car.
Old 01-30-2017, 01:57 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Easy part to score? I'm assuming places like Summit will have these?
Old 01-30-2017, 09:16 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Any autoparts store can get the brake switches. No need for mail order.
