built 700r4 transmission
1 Post
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Th700r4 transmission built for approx 700hp
Hardened input shaft/ Drum assembly (30 spline)
Extreme duty shell/bearing assembly
Extreme duty reaction carrier shaft and bearings
Extreme Duty rear 5 pinion planet gear
Extreme Duty front 5 pinion planet gear
TCI Reverse Manual Valve Body
Elevated Pressure Regulator Spring
13 Vane Pump Installed
29 Element sprag
10 Clutch pack installed (alto red)
Alto Carbon fiber band
Billet Servo (more apply then the corvette servo)
0.500 Mega Valve
Polished Transmission Pan
Lokar Firewall mount dipstick
9” convertor (stalls at approx 3000 rpms) (this convertor has no lockup capabilities)
This transmission needs to be rebuilt, the 1-2 shift is getting funky
$1200 for everything listed above, parts alone is $2500 easy!!!
email me camaroracer1992@yahoo.com
29 Element sprag
0.500 Mega Valve
Car: '86 TA 305 F, '89 GTA 8
Engine: F 305 TPI, 8 350 TPI
Transmission: 700 r4
Re: built 700r4 transmission
Still got it? I shipped one of them in a Black Plastic Cargo tote, using FEDEX, it wasn't to bad as far as cost.
morrow
01-13-2024 12:29 PM
ambainb
04-25-2016 09:21 PM
someone972
08-30-2015 12:52 AM
