[WI] LOTS OF PICTURES -- fluid coolers, wheels, HAWK pads, TPI parts and more
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Here are all the parts I’ve got for sale. Some of the items I have had listed separately before but never completed the sale because life got in the way but everything seems to be under control now so I’m going to try selling again. I would like some extra room in the garage this winter for the 2 wheeled projects so if you don’t like the price shoot me an offer and hopefully we can work something out. I’ll add stuff as I find more and remove things as they sell. If you pay with check I’ll have to wait for it to clear before anything gets shipped. If you use PayPal I’ll cover any fees and can ship hopefully within a day or two if not the same day.
-- Oil/tranny cooler with filter relocation brackets made by Perma-cool.
$80
-- This was used as a tranny cooler
$5?
-- Stacked plate style 3/8" hose barb fluid coolers. Not including mounting tabs or hose barbs, the cooler is 11"x10"x3/4".
$30
-- C5 Z06 Speedline front wheel comes with centercap. Some scratches but otherwise good.
$70
-- 24mm rear swaybar with poly bushings and endlinks used for ~1600 street miles and two autocross events. It was way to stiff for my setup so off it went. It was painted gloss black and I would include a picture but I’m sure we all know what a black swaybar and red poly bushings look like.
$70
-- 21/22mm rear swaybar with old rubber bushings and no endlinks. I put this back on the car when the 24 was too stiff but I’ve got an adjustable swaybar in the back so now I don’t need this. It was painted gloss black and I would include a picture but I’m sure we all know what a black swaybar looks like.
$30
$80
$5?
$30
$70
$70
$30
1 Post
Car: 1987 IROC-Z
Transmission: TH350
Re: LOTS OF PICTURES -- fluid coolers, wheels, HAWK pads, TPI parts and more
-- 87-92 style stock strut mount retainers. They were replaced with new ones when I installed the J&M strut mounts so these were tossed in a bin and forgotten about.
$10?
-- HP+ front pads for stock brakes never used and only taken out of the packaging to look at them.
$70
-- HPS rear pads for stock brakes never used and only taken out of the packaging to look at them.
$50
-- Stock dual electric fans
$60
-- Stock dual fan upper mount
$15
-- Stock dual fan lower mount
$15
$75 for all of it.
$10?
$70
$50
$60
$15
$15
$75 for all of it.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
-- C5 Corvette front brake parts. There is a complete caliper, a disassembled cut caliper, some braided brake lines, and miscellaneous anti rattle pad clips. I’ll sell it all together or sell parts of it but nothing from the complete caliper on the left will be separated.
1 Post
Car: 1987 IROC-Z
Transmission: TH350
-- Brand new left side front LS1 caliper with a used caliper bracket.
$50
-- 98-02 f-body rear calipers, brackets, and unknown pads clearanced for drag wheels. The other bracket had the guide pin rusted in it but I can try finding it and ship it if you want to try getting it out.
$40
-- 93-02 F-body rear end sensor. Looks like a tab was broke off and I'm not sure if it works. It’s a little dirty from sitting on the work bench for the last couple weeks.
give me an offer
$50
$40
give me an offer
1 Post
Car: 1987 IROC-Z
Transmission: TH350
-- 85-87 IROC-Z wheels bad rash on a front wheel (from letting a friend drive the car) and some clear peeling on all. The tires are already off. The first picture is the wheel with the road rash. They are all straight and great for a daily driver just don’t expect anything super nice.
$160 (I will drive to meet someone if they help cover gas but would prefer you pickup)
-- "TUNED PORT INJECTION" throttle body plate with gasket
give me an offer
-- Stock TPI throttlebody, plenum, and intake manifold.
give me an offer
give me an offer
give me an offer
1 Post
Car: 1987 IROC-Z
Transmission: TH350
-- UMI tie rod adjusters never out of their packaging
$30
-- MSD 8.5 Superconductor spark plug wires with extra boot and crimps. Not sure what part number they are. The distributor ends of the wire are goofy and stick out beyond the boot. The coil wire is not included.
$35
-- UMI black powdercoated adjustable rod/poly PHB bar missing rod end. There are some knicks in the powder coating for being used for ~4k street miles but otherwise its fine.
$60?
-- SBC bow-tie timing cover. The second pic shows a scratch in the paint
$15
-- SBC power steering pump brackets from an AC equipped car
$10
-- Stock brake master cylinder and drum proportioning valve from my 87 IROC
$15
$30
$35
$60?
$15
$10
$15
1 Post
Car: 1987 IROC-Z
Transmission: TH350
-- 4th gen automatic leather shift ****
$10
-- 3rd gen auto leather shift **** worn through in one spot
cover shipping or free with another item
-- Firebird map pouches all in pretty good shape.
$20 shipped for all four or give me an offer for one
Parts I will trade for:
-- stacked plate oil cooler with -10 fittings or larger
-- oil filter sandwich plate with 180* temp controlled cooler bypass
-- drivers side 3 channel brake line from a 98-02 F-body rear end
-- complete ebony (00-02) parking brake setup
-- new unused Hawk HPS pads for 98-02 rear
-- braided hose for coolers
-- AN hose end install kit
$10
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
hi, how much for all of the front brake stuff... (all 3 calipers and associated parts)?
thanks, greg
thanks, greg
Car: 1989 Camaro RS
Engine: Soon to be LS.
Axle/Gears: Need some
How much for both the MSD wires and the UMI adjust sleeves shipped to 76957?
1 Post
Car: 1987 IROC-Z
Transmission: TH350
*I forgot to mention in the pm that the coil wire is not included*
Car: 1987 Iroc Z
HI, still waiting on a price for the brakes to 71047.
thanks
thanks
Car: 85 Trans Am
Engine: 350: cam, aluminum heads, etc
Transmission: WC 5 speed
Axle/Gears: Dana 44, 373
Interested in the wheels, I'm in Appleton so I'd come pick them up. Pm me please. Thanks!
1 Post
Car: 1987 IROC-Z
Transmission: TH350
I'm pretty sure I just finished responding to everyone. If I missed you let me know.
1 Post
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
what would be shipping of the timing cover to canada if you are willing to ship. Thanks
Car: '85 Z28
Hey there,
Do you have any of the wiring for the dual electric fans? I am in Milwaukee right now and could possibly pick up.
Thanks,
Colin
Thanks,
Colin
1 Post
Car: 1987 IROC-Z
Transmission: TH350
More PMs have been sent out.
No wiring with the fans.
1992 Trans Am
05-10-2023 07:19 PM
