[VA] Yella Terra pedestal mount shaft rockers
Old 11-18-2011, 10:40 PM
Want a title? Post!
Steve85's Avatar
Car: 85 Corvette
Engine: 408 Victor E, AFR 210
Transmission: Richmond 6spd
Yella Terra pedestal mount 1.5 ratio rockers. For much better stability at increased RPMs. Had these on my 210 AFRs.
"YTRYT6009 Intake and exhaust rockers are joined in pairs on a shaft that is 22% larger and engineered for extreme RPM. Maximum width bearings deliver greater rigidity, resistance to breakage and superior load carrying ability, eliminating the need for screw-in studs, guide plates and stud girdles" $300
Old 11-21-2011, 01:07 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Yella Terra pedestal mount shaft rockers
whats needed to put these in place of pressed in shaft mounted rockers?
Old 11-21-2011, 02:00 PM
TommyG's Avatar
Car: Chevy
Transmission: 700R4 Automatic
Do your rockers have any offset on the intake?
Old 11-21-2011, 02:54 PM
Want a title? Post!
Steve85's Avatar
Car: 85 Corvette
I think you mean the regular rockers on pressed in studs, if so, the studs would have to be removed and those holes tapped to accept these bolts. I don't think it's hard, I seem to remember it was a popular thing to do to allow for larger screw in studs in place of the pressed in ones.
No offset on the intake.
Old 11-21-2011, 02:58 PM
travis401's Avatar
Car: 91 Camaro RS
normaly for the screw in studs you have to pull the studs then machine the stud bosses down then drill and tap them. if these dont need the bosses machined down i might be interested.
Old 11-21-2011, 03:08 PM
Want a title? Post!
Steve85's Avatar
Car: 85 Corvette
Forget all that and buy my pre-eliminator AFR 210s
Old 11-21-2011, 03:21 PM
TommyG's Avatar
Car: Chevy
and of course I Needed offset. what's your asking price for the 210's ?
Hotrodboba400
12-10-2019 07:07 PM
Jorlain
10-08-2015 01:57 AM
New2Chevy
09-28-2015 12:35 AM
Hotrodboba400
09-02-2015 07:28 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
Quick Reply: [VA] Yella Terra pedestal mount shaft rockers
