650 HP 396 Small Block Chevy
Old 12-05-2011, 06:26 PM
Want a title? Post!
95zedder's Avatar
650HP 396 Small Block Chevy
LT1 Block
Bored 0.030 over
Decked to 9.000 deck height
Line Bored and Honed
Clevite 77 H Series Main & Rod Bearings
Durabond Performance Cam Bearings
Eagle Billet Splayed Main Caps
ARP Main Studs for Splayed Caps
ARP 12-Point Head Studs
Eagle ESP 4340 3.875 Stroke Crankshaft
Eagle ESP 4340 H-Beam 6.00 Connecting Rods
Forged Flat Top SRP Pistons
Speed Pro File Fit Piston Rings
Crane Cams Custom Small Base Circle Soild Roller
Cloyes Billet Double Roller Timing Chain
Comp Cams Endur-x Solid Roller Lifters
Comp Cams Custom Length Hi-Tech 270* Pushrods
Moroso Fabricated Aluminum Center Bolt Valve Covers
AFR 227cc CNC Competition Ported LT4 Heads massauged by Agostino Racing
Manley Severe Duty 2.100/1.600 Valves
Crane Cams SOlid Roller Springs
Crane Cams Titanium Reatiners and 10* Locks
Jesel SS Shaft Mount Rockers
Melling Performance High Volume Oil Pump
ARP Oil Pump Driveshaft
Canton Oil Pump Pick-up
Canton 7qt Road Race Oil Pan
Fluidampr LT1 Balancer
The engine is 4 years old and has about 8000km on it. It Was Professionally Built at Engine Technology in Cambridge, ON. The engine makes 658HP @ 7000RPM and 568ft/lb @ 5500RPM.
http://www.racingjunk.com/Engines-Co...ock-Chevy.html
Old 12-07-2011, 07:33 AM
Want a title? Post!
95zedder's Avatar
Re: 650 HP 396 Small Block Chevy
This engine will acept any regular SBC Intake and I will Include a Meziere Water Pump for free.
jhawkeye
05-25-2022 06:33 PM
9192camaro
16
02-03-2019 12:21 AM
theshackle
03-05-2017 06:37 PM
Mickeyruder
09-02-2015 02:45 PM
BlackphantomZ28
08-22-2015 01:00 PM
Quick Reply: 650 HP 396 Small Block Chevy
