LT1 intake modified for L98 $450 or best
Want a title? Post!
Car: 1985 iroc
Engine: 5.0
Transmission: 700r
Axle/Gears: ?
I started this project and its just about finished, I ended up with another intake to use so I no longer need it. I set this up on an end mill so its correctly. I didn't use the center bolt holes as they are not necessary. Even Gm did away with them later on the vortec intakes. I was going to attach a cover on the back instead of filling it in like most do. Then you could use a vacuum port there for brake. Please email with any questions you have. It also comes with a new billet moroso thermostat housing, anodized black. Thanks for looking...
Re: LT1 intake modified for L98 $450 or best
Did you take care of the area where the EGR ports on the cylinder head line up with the LT1 intake as the LT1 intakes are a tad too short in that area (doesn't cover the EGR port entirely), causing an exhaust leak in the engine underneath the intake manifold...
- Rob
- Rob
Want a title? Post!
Car: 1985 iroc
Engine: 5.0
Transmission: 700r
Axle/Gears: ?
This intake was going on a c4 corvette, as you no they have no crossover on the l98 aluminum heads. I had no need for this mod but it could easily be done.
Thanks for looking
Thanks for looking
