Dressed HSR with extras
Old 04-14-2012, 06:23 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Fully dressed Holley stealthram for conventional SBC (not vortec). I ran it for 7 years in my chevelle, going to LS1.
Package includes intake, plenum, billet 2x58mm throttle body, fuel rails, cross-over, adjustable fuel pressure regulator, MAP, coolant temp, and air temp sensors. TPS, IAC are included on the throttle body. Does not include injectors.
This package also comes with working GM small cap HEI distributor, set of plug wires, distributor hold-down, Lokar throttle cable kit, spare non-adjustable fuel pressure regulator, spare adjustable fuel pressure regulator, TPI/LT1 nitrous plate, spare short fuel rail (in case you want to run normal bypass regulator), spare front cross-over, hand full of rail fittings, stack of new plenum gaskets, 2 new throttle body gaskets, 2 extra sets of throttle body bolts, water neck and 160deg thermostat, and new set of 1205 Fel-Pro gaskets. Everything pictured..
The base has been ported (gasket matched to 1205 and radiused entries at the plenum). I welded solenoid bracket mounts to the base (can see in picture between runners) and had also added a raised fuel rail mount to accomodate NOSzles, however they have been functionally removed (cannot see the mod, hidden behind rails). Intake is used and could use a little cleaning but is in perfect working order.
$750 shipped with everything.
Call/text (7won2)435-9ate63 (7am-10pm please)
PM for paypal address
Old 04-15-2012, 11:39 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Re: Dressed HSR with extras
Will u part it out hsr gaskets, nos plate, and what's that red afpr its not holley, and the wires what's the miles wish I saw u be4 I got mine
Old 04-17-2012, 04:41 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Will not part out.
Accepting offers..
Old 04-17-2012, 08:36 PM
ikillu's Avatar
Car: 91 Z28
Engine: 383 stroker HSR
Axle/Gears: 3:73 posi
pm sent
Old 04-17-2012, 10:47 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Everything is sold.. thanks!
RS Reaper
10-17-2018 07:52 PM
mattcanty
10-12-2015 11:08 AM
Night rider327
10-09-2015 09:25 AM
loud91rs
10-05-2015 10:05 PM
mike22115
09-28-2015 04:49 AM
Quick Reply: Dressed HSR with extras
