GM Steering Shaft Upgrade
#101
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
Re: GM Steering Shaft Upgrade
1 Left on this batch.
PM me if you want one.
#103
Engine: 305/350/454
The set screw should be snug to take out any play. Trust me that little screw won't stop anything in a collision.
#106
Engine: 305/350/454
Have few Solid GM Shafts & 2 Jeep Shafts that will be ready to ship this weekend.
Shipping to Canada adds $35, sorry i don't set the rates the post office does.
PM me with what kind you want to get on the waiting list.
#107
Engine: 305/350/454
I have 2 GM shafts with rubber isolator left and ready to ship.
#109
Engine: 305/350/454
I have 2 Solid GM Shafts ready to ship.
#114
Engine: 305/350/454
I have a couple Solid GM Shafts and Bearings available.
#115
1 Post
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I'm considering this. I'm from Tally too. This wouldn't be a bad idea when I'm replacing my steering box. Do you need mine as a core?
#116
Engine: 305/350/454
Nope no core needed, you in Tally now? I am by Lake Jackson.
I have a few on the way but i believe all are spoken for.
I will let you know.
#117
Engine: 305/350/454
Got a couple more Solid Shafts ready to ship.
#118
Engine: 305/350/454
Got another batch.
#119
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Engine: 305/350/454
Responded & Shipped.
Thanks.
This brings up a point, i sell these on many different message boards as well as through e-mail.
I try to sell on a 1st come 1st serve basis so i have to go through many PMs and E-Mails to see who contacted me 1st before i respond with payment info. I do my best to respond quickly but sometimes life & work get in the way.
All out of this batch, PM me to get on the list for the next batch.
#126
Engine: 305/350/454
#127
Engine: 305/350/454
I have another batch on the way. as well as some bearings.
PM me if you want to get on the list.
#128
Engine: 305/350/454
Have shafts ready to ship along with bearings.
#130
Engine: 305/350/454
Yes they require the same notch.
#132
Engine: 305/350/454
They are $70 shipped to the states.
I may be able to help you fix your Jeep shaft.
You have a PM
You have a PM
#133
Engine: 305/350/454
Have another batch on the way, 4 Solid & 3 with Rubber Isolator.
I also have Bearings, Cleaned Painted & Greased.
PM to get on the list.
#134
Engine: 305/350/454
Got them in today, 2 rubber and 2 solid already spoken for.
They will be ready to ship Monday.
PM Me if you want one.
#135
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Looks like im stupid... which is the one with the isolator from??
im goin to the salvage yard to do this so im asking
#136
1 Post
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
I have a new product for you die-hard GM fans that refuse to put a Chrysler part on your car. I have done some research and testing and now have available a GM steering shaft upgrade. In addition to being a GM part they also have a set screw you tighten after installation to eliminate all shaft movement, they have a metal bushing instead of the worn out mostly broken plastic bushing on the inner shaft and for those of you with large tube headers the shaft is the opposite of the Jeep shaft so the small end attaches to the steering column allowing the most available clearance.
This is the end that attaches to the steering column:
This is the steering box end, note how nice the u-joint is:
Set screw in the center:
Metal bushing in lieu of plastic:
As with everything i sell these will be prepped, painted, greased and ready to install.
These GM units will be $70 shipped to the lower 48.
I only have 2 of these in stock so hurry.
PM me if your interested, please title it GM Shaft.
#137
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
If you have any Astro bearings how much is one shipped to 95472? If not, which year Astro (or Safari?) can they be taken from?
#139
Engine: 305/350/454
I have a question, I've purchased a shaft from you awhile back, and I like the fit and finish of the product, but are these units CLOCKED? I saw a youtube vid that states that they need the end ground down so it can be knocked off repositioned slid back on and tack welded, do you perform this operation on every unit?
If you are having an issue please feel free to PM me and i will help get it straight.
#142
Engine: 305/350/454
Sold out of this batch and all orders have been shipped.
I have a few more on the way so PM me if you want one.
#144
Engine: 305/350/454
OK Just making sure everything was good.
This was discussed in an earlier post.
I clean them up, remove the column end, re-clock it 90 degrees, press it back on and tack weld it just to make sure its not going anywhere. Then i clean the bolt threads, spread the ends & test fit on a steering column, sand & paint them gloss black. Before shipping i grease the inside of the shaft, wrap both pieces in foam and stretch wrap for shipping.
#145
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
So what is your current stock like right now? I pulled my s/s out for engine bay work and don't want that sloppy dirty thing going back into my car.
#146
Engine: 305/350/454
I am out of stock right now but have 4 more on the way and going to hit my local yards Friday to see if i can get some.
If you want to get on the list please send me a PM, that's how i track who is in what order on the waiting list.
#147
Engine: 305/350/454
Got a couple more Solid Shafts in stock.
#148
Engine: Cammed 6.0L LSX
Thanks again. This guy means business, had mine shipped out the next business day and used 2nd Day Priority mail. Got it yesterday and it looks really nice.
#149
Engine: 305/350/454
Thanks, I appreciate it.
I do my best to make sure everyone is happy.
