GM Steering Shaft Upgrade
#301
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
Re: GM Steering Shaft Upgrade
I have a couple with Rubber Isolator in stock and ready to ship.
I also have a dozen solids that will be ready Monday.
PM me if you want one.
#302
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
Got mine today thanks, looks good the joints are not sloppy so I am a happy camper. Should bolt right up with a little grind
#303
I was just letting you know. I tried and the bearing would not even try to fit on the shaft. then I looked it up and there's a thread referencing this problem saying you have to dremel down the shaft to make it fit. The plastic retainer is the only piece that fits. https://www.thirdgen.org/forums/susp...teering-2.html
On the other hand, the solid shaft went on without a problem.
#304
Engine: 305/350/454
I got another batch of Solids ready to ship.
#305
Engine: 305/350/454
Have plenty in stock ready to ship.
To help eliminate any future issues see the picture below. This is how the shaft is supposed to be installed with the set screw in the groove.
Before you notch your steering column install the lower end on the steering box, then with the shaft positioned as shown mark the steering column for the bolt.
I thought it was pretty self explanatory but according to a recent buyer that did it the opposite way i clocked the shaft 180 degrees off and now expects me to pay to ship it back to me, modify and ship it back to them all at no cost to them.
If anyone in the future is not 100% sure of how to install the shaft please contact me "Before" you do it wrong.
#309
Engine: 305/350/454
Dear Ken,
We completed our review and decided this case in your favor. Any money that may have been temporarily held has been returned to your PayPal account.
During our review, we’ve found that you had sufficiently described the merchandise.
Transaction Details
Case number: PP-003-593-949-546
Buyer's name: Kyle
Buyer's email: kyle
Buyer's transaction ID: 0TY906276U860171Y
Transaction date: December 7, 2014
Transaction amount: $70.00 USD
Your transaction ID: 0K789844PN846163U
To learn how we review and resolve claims, you can view the PayPal User Agreement, which you accepted when you created your PayPal account. Simply click Legal at the bottom of any PayPal page.
Please note: Records of all claims are kept in the Resolution Center for your convenience.
Sincerely,
PayPal
Kyle,
As i said MANY times in our conversations i am sorry you are having issues.
I will get some pictures posted tonight showing how the unmodified part of the shaft is not always the same.
I really don't feel i was being rude however i did get aggravated after you threatened me with bad feedback and filing a PayPal dispute.
Since you wanted to bring this into the public forum i guess we can let everyone else decide.
Re: Steering shaft
Quote:
Originally Posted by MC87SS
Quote:
Originally Posted by KYLE87
Payment sent. Thanks
Kyle
Got it, Thanks.
I forgot to grab some this morning to bring to work so I will ship tomorrow.
Received today and have a question.
Once installed the set screw should should go down and face into the indented track right? Reason I ask is after installing mine how I have seen it done on all of the threads online The indented track is on the bottom side and the set screw is on the top. I think it might be possibly clocked wrong by 180 on the side that connects to the firewall
Here is a picture. See how the track is on the bottom side instead of the topside where the set screw is.
Is this correct or is something off. Just wanna be sure. Thank you
Kyle
It may actually be better, the set screw would be even tighter this way.
I would think so too but I think it may be stripped, it spins and never feels tight. That's why I wasn't sure if that groove mattered.
The only thing i can suggest is to notch the other side of the steering column and rotate the shaft.
As for the set screw it may be ok once you rotate the shaft if you put some locktite on it.
I don't understand why I should haft to modify th shaft anymore than the instructions say. Every install I have seen is exactly how I did mine on the steering column end. I shouldnt haft to modify it anymore or the otherside. Its rotated differently on the shaft itself on mine compared to others installs. It's not my fault it was modified 180 off.I Would be fine with it if the screw held like that but as far as I can tell the screw feels stripped. I unhooked it from the column and rotated it with it towards the groove to see if it would tighten that way and it doesn't. I shouldn't haft to put loctite on it.
Sorry hit enter to soon.
If you want to ship it back to me and send me $12 for return shipping i can fix it for you.
I'm not trying to be rude but I honestly feel it should have been done right in the first place and no need to pay more and send for repair.
You would not have had to modify it if you had done a test fit before you notched the column. There is no right or wrong way, even the shafts in stock form are not always turned the same way.
The set screw was not stripped when i sent it to you. When its screwed in to the grove the head bottoms out before you can strip the screw.
I am sorry you are having issues but i am not sure how you installing it wrong is my fault.
I have sold 100s of these with out any issues.
My offer still stands to spend the time fixing it for you but i don't feel i should have to pay the shipping.
I did do a test fit. I had to in order to know where to make the notch for the screw. I Installed it the same way everyone else does. I have seen several pictures of how it is supposed to be. It wasn't until I went to set the screw I realized it was 180 off. Setting the screw this way it never tightens down and appears stripped.
As you just said "spend the time fixing it". If it's correct as you say it is, why would you need to fix it? That's what bothers me about you thinking I should pay shipping. How is it fair I pay for shipping when I received something that wasn't done correctly.
If you do not want to make it right that is fine. I will take it up with PayPal and leave appropriate feedback on the boards . I hate to do that and I don't like doing business that way and always attempt to give the seller a chance to make things right but if your not going to take care of it I haft to do what I haft to do.
Sorry i don't see how you can say you installed it the same way everyone else did, there is no way you can tell how everyone did it. how do you know their wheels were not turned slightly? I can show you pictures of it installed with the bolt in the down position.
You keep saying it was not done right however there is no right or wrong way, only what side of your column you notch. I only offered to modify it to try to make you happy. Like i said in an earlier message all you have to do is rotate it on your steering column and it will work as designed. If you were not confident you knew how to install it or how it should be installed you should have asked before you notched your column and stripped the set screw on the shaft.
I am sorry you are having issues and already offered to modify it to meet our needs.
Even though you damaged the part If you want to return it for a refund you can however the refund will not include the $12 i paid to ship it to you.
Let me know what you want to do.
If you still don't feel i am doing my best to resolve this issue then i guess we will have to let paypal decide.
Look at the very first picture in your post. It is clocked how it should be in that photo. If you don't stay consistent that's not my fault. Your seriously gonna accuse me of stripping the set screw? That's Bull and I think I'm more upset about that than it appearing to be be notched 180 off. I simply tightened it and it never got tight. It doesn't take a rocket scientist to turn a screw till its tight.
I'm not gonna sit her and argue with you. If this is how you do business and you feel good about it then good for you. Pretty sad your gonna make money off of this board and not stand by your product. I don't do business that way
The picture in this post shows it the same way as yours.
https://www.thirdgen.org/forums/engin...ml#post5795631 (GM Steering Shaft Upgrade)
What you are not understanding is the lower part that mounts to the steering box is not modified and some are rotated each way. It all depends what side of the steering column you notch.
As i said before all you need to do is slide it off the steering column, turn it 180 degrees and slide it back on. That side may have the flat spot on it so it may not even need the notch.
Like i said before i have 100s of satisfied customers so yes i do feel good about how i do business. I stand behind everything i do but i can not be liable for your not understanding how it works.
Again i am sorry you are having issues and i am willing to help but you need to take some responsibility.
Let's be clear. I clearly understand how it works, it's not a matter of that. I installed the same way I have seen pictured countless times.
What responsibility do I need to take? I followed the instruction I was given.
So you don't make your parts consistently the same? Maybe you should highlight that so people know they may be different and you may haft to notch it differently case to case. And you take responsibility for that. I would assume my solid shaft would be the same as any other you sell. I take responsibility for assuming all of your products were assembled the same, most people assemble parts and stay consistent to avoid confusion.
So assume I rotate it and the set screw still doesn't tighten. Where do I go from there? Is it safe leaving it loose?
Done!
That 1st picture was one of the 1st shafts i got, if you look at every other picture after that until now they are exactly like yours. As i said the lower parts vary from the factory, nothing i can do about that.
The set screw is only there to help reduce any rotational play if there is any. There is no way the shaft can come apart once installed.
That is why i mentioned locktite in a previous post.
If you add a drop of locktite on the set screw before you screw it in i would think it would be fine as long as it wasn't stripped out to bad.
Transaction Details
Buyer's name: Kyle
Buyer's email: kyle
Sincerely,
PayPal
Kyle,
Re: Steering shaft
Kyle
Got it, Thanks.
Kyle
Done!
#310
Engine: 305/350/454
I have plenty of solids and 1 with rubber isolator in stock and ready to ship.
#311
Car: 1989 Trans Am GTA
I haven't installed mine yet. ( car in storage till spring) just looking at it. It's quality. I'm a certified welder. His welds are above par. Would diff buy again
#312
Engine: 305/350/454
Thanks Brett, i try to supply the best product i can.
Wishing everyone a Merry Christmas.
#313
Engine: 305/350/454
I just finished prepping another batch.
10 solids and 1 with rubber isolator ready to ship.
#314
Engine: 305/350/454
Down to 5 Solids and 1 Rubber.
#315
Engine: 305/350/454
Pay Pal Decision on the issue above.
Dear Ken,
Transaction Details
Buyer's name: Kyle
Buyer's email: kyle
Sincerely,
PayPal
Dear Ken,
Transaction Details
Buyer's name: Kyle
Buyer's email: kyle
Sincerely,
PayPal
#317
Engine: 305/350/454
No it doesn't say cancelled, it says they decided in my favor.
Nice try.
Funny how you are the only one out of hundreds that had a problem with my product or customer service.
If it makes you feel better to say you cancelled the claim then that's your choice.
#319
Engine: 305/350/454
I did have an issue with 1 batch a long time ago that i clocked wrong, i immediately contacted everyone that received one and paid the shipping both ways for me to fix them. I do step up and do the right thing when its my fault.
Again, sorry that you didn't fully understand the install procedure.
I did step up and offer to modify and fix what you broke at no charge if you paid the shipping.
As you said above but didn't follow through no sense beating a dead horse.
The facts and past positives speak for themselves.
#322
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
I don't really want to read 7 pages; What benefit does this bring me? (88 GTA 5.7 auto is what the car was)
What is the difference between solid and rubber?
#323
Engine: 305/350/454
This shaft replaces the rag joint and tulip joint used on the stock shaft with U-Joints.
The result is a tighter, more responsive steering.
The solid doesn't have a rubber isolator, i never noticed a difference on my car but the theory is the isolator helps reduce "Road Noise"
#324
Engine: 305/350/454
Down to a couple Solids left.
#325
Engine: 305/350/454
Got 7 more today.
They will be prepped and ready to ship Monday.
#327
Engine: 305/350/454
Down to 2 solids left.
#328
Engine: 305/350/454
2 Solids ready to ship.
I also have 22 more that need to be prepped. I will have plenty of Solids and a few with Rubber Isolator ready next weekend.
#329
Engine: 305/350/454
Plenty in stock.
#330
Engine: 305/350/454
Sold out of this batch.
I will try to get more this weekend.
PM me to get on the list.
#337
There is a lot of these’s steering shafts being sold on eBay. Or PM them at Firechicken@zoho.com I got a few from them and they are awesome!!! https://rover.ebay.com/rover/0/0/0?m...2F202498204446
#339
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
I'd like to do this to my 1983 Camaro. Who sells them now? What year is the shaft from the Astro Van?
Speed Racer (09-07-2021)
#341
1 Post
Car: CAMARO RS 25th Anniversary Z03
Engine: L03 V8 5.0
Transmission: THM 700 R4
Axle/Gears: 2.73 OPEN
Here is the type with the rubber isolator.
These are so much nicer then the Jeep Shafts in my opinion.
Please specify if you want one of this type, i can get them if there is a desire for them.
Attachment 356669
Attachment 356670
Attachment 356669
Attachment 356670
Do you still selling this shaft?
MC87SS
91
07-22-2023 02:11 PM
ghettocruiser
06-21-2015 05:06 PM
RaverRacerX
05-19-2014 05:06 PM
jdperformance
02-11-2013 08:44 PM
