FS: Holley Commander 950 MPFI
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... SOLD ..... ... Holley Commander 950 ECU with Main wiring harness , MPFI injector harness , and Lap top Communication cable ... also included is the software discs and full 114 page install and instruction manual ... this controller will work on L98 , LT1 , and similar multi-point fuel injection manifolds including Mini-ram , Stealth Ram , Single Plane adaptions and FIRST fuel injections ... Other harnesses are available including Throttle Body Units ... The 950 will control just about any gas combo that uses fuel injectors .......... $600.00 shipped .............
Car: '87 Vette C4
Re: FS: Holley Commander 950 MPFI
..... Still Available .......................
Car: '87 Vette C4
......... Still Available .............
Car: '87 Vette C4
.......... Still Available ............
Car: '87 Vette C4
........... somebody needs this ! ...............
Car: '87 Vette C4
.......... You can piggy-back this set-up to your OEM computer and get an EASY to tune Engine control unit ... it uses all GM sensors and is virtually plug and play ... tune with your laptop ... you can spend just as much buying chip burning gear and will still be dealing with the quirky/over protective OEM controller ... I did my own tuning for years ... tried several mail-order tuners ... I wish I had tried the Holley C950 first ... I've been running one just like this for two years now and couldn't be happier ......
Car: '87 Vette C4
....... This set-up will work on TBI systems also with the appropriate injector harness available from Holley ..........
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
This is a great deal. If I was still playing with GEN 1 motors, I'd be all over this.
1 Post
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
Is this still available?
appologies, i see above that you marked the original post sold.
RedLeader289
05-28-2019 01:47 PM
Royal_Z
09-30-2015 08:45 PM
