[NJ] Various parts
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Various parts
Digging around in the garage today I realized I have a few to many parts and could use the room
- offenhauser 360 degree dual plane intake $75 pre 86 sbc
- edelbrock 2101 performer $50
- complete v belt abc accessory drive old style for long water pump. $25 alternator,a/c compressor, ps pump, pulleys, brackets, etc
- crank and water pump pulley for serp/v belt 82-87 $40 shipped
- steel driveshafts (2) $20 ea
- stock torque arms $15 ea
- 700r4 torque arm mount $25 shipped
- sbc one piece rms 153 tooth flex plate $10
- 1985-87 tpi alternator, a/c and smog pump brackets $25
- (2)sbc oil pans drivers side dipstick $15ea
- brand new sbc oil pan ps dipstick $25
- lg4/tbi air cleaner assembly $10
- tpi/2.8 intake top and bottom $40 ea. x2
v6 parts
- newer a/compressor and rubber lines $35 shipped. Turns over free but exact condition is unknown
- newer alternator $30 shipped
- 2.8 ecu w/ 5 spd prom $50 shipped
- 2.8 throttle body $30 shipped
-complete mpfi manifold 3 pieces $50 + ship
- 2.8/3.1 fuel rail $35 shipped. I know it needs a fpr diaphragm,injectors are included but the condition is unknown
- (2)2.8 radiator shroud/top for an electric fan $30 shipped uncracked
- 2.8 flywheel $20 will probably need resurfacing or light cleaning.
- egr valve 2.8 $20 shipped
- 2.8/3.1/3.4 t 5 bell housing $80 shipped
v6 parts
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Re: Various parts and 1984 berlinetta part out
I'll take the roller cam retainer and ties.
Everything there? Decent shape? Got a picture? PM me payment info please.
1 Post
Engine: 305, 355
Mcmxgateman, pm sent. I am trying to upload pictures now. Working on my iPhone and its not working for me right now
1 Post
Engine: 305, 355
Roller cam ties and retainer sold.
1 Post
Engine: 305, 355
Bump. Added a few more parts that I found to the list.
1 Post
Engine: 305, 355
Here's the best pic I have right now. Car has a digital cluster, tach is part of the entire cluster
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
oh, I'm looking for analog tachs. Thanks anyway!
1 Post
Engine: 305, 355
Jackson nj. Basically 5 min from six flags.
1 Post
Engine: 305, 355
Sorry, I do not have a dipstick or tube I bought the car as a roller. I also do not have any other dipsticks from other cars.
1 Post
Engine: 305, 355
Bump The berlinetta is gone, list has been updated
1 Post
Engine: 305, 355
Here's a pic of the damaged one, the only one I have on hand right now. If you want any more send me an email address and ill get them to you.
Car: 1988 Pontiac Firebird GTA Spec.
Engine: Tuned Port Injected 350 V-8
Transmission: Automatic
Axle/Gears: 3-27-1
Re: Various parts
do u have air dam for 5.7 v8 Gta WSS Pontiac 1988 ?
Mass air flow sensor?
1 Post
Engine: 305, 355
Re: Various parts
Yes I still have the springs. Unfortunately I do not know the mileage or how worn they are they sort of basically came with the 85 I bought, went a different direction and am not using them.
Car: 1992 Camaro
Engine: v6 3.1
Re: Various parts
I actually want the smog pump with pulley. Really just concerned about the pulley. Will it fit my 1992 v6 rs? The pulleys vary from year to year I think?
1 Post
Engine: 305, 355
Re: Various parts
the f41 box has 106k miles on it. The z28 box I think was around 130-140k, the car it came from is long gone. Im not sure of the turning ratios of either box but ill check on that tomorrow.
1 Post
Engine: 305, 355
Re: Various parts
The z28 box is 2.5 turns lock to lock. It does have rust and a little scale on it but it will clean up decent.
1 Post
Engine: 305, 355
Re: Various parts
Here's the f41 box. The pitman arm but needs to be torqued down. The ratio is between 2.5. And 2.75 turns lock to lock. I'll double check it once I get the rag joint off.
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
Re: Various parts
Is the old v belt set up for no acc' hole heads like #461 #462 double humps?
1 Post
Engine: 305, 355
Re: Various parts
It's for a motor with a long water pump and head accessory holes. It was removed from an 85 suburban. Sorry for any confusion, When I meant old style I meant older than the third gen half serpentine half v belt type setup.
#42
Car: 85 Trans Am
Axle/Gears: 373's
Re: Various parts
O ok man its all good I thought thats what u might have meant..
. Been on the look out for some brakets to make thease double humps work thought I might have lucked up with a complete setup
LT1Formula
20
11-14-2015 12:02 AM
