[KY] Strange 12 Bolt Narrowed Rear End - BRAND NEW
Want a title? Post!
Brand New Narrowed Strange 12 bolt rear end for '82-'02 F-Body (complete bolt-in). It's 3" narrower per side than a 93-02, and 2" narrower per side than a 82-92. Housing will work with either 3 channel or 4 channel ABS. You would just need to install your reluctors and/or sensor with adapter. I will include a set of 93-02 backing plates. 82-92 f-bodies will require these, along with 93-02 rear brakes.
33 spline axles, 3.08 gears with Strange posi unit, 1350 u joint, Lucas oil, and additive.
Just purchased on 9-2-14. It was $2930 with shipping. Will take the first $2500 cash. Will not ship.
Located just 5 min north of Louisville, Ky, in Clarksville, IN.
812-207-0303 (Text is best)
-Rob
-Rob
Re: Strange 12 Bolt Narrowed Rear End - BRAND NEW
Would this be only 1" narrower per side than the 82-92 axles? If the 93-02 axles are 2" wider per side than the 82-92 and it is narrowed 3" from 93-02 that would be 1" narrower per side than the 82-92.
Not trying to flog on you about it, I am actually looking for an axle 1" narrower per side than my stock 82-92.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
1992 Trans Am
08-08-2015 08:16 PM
