Complete tubular k member set up, 12 bolt, turbo 350 with brake
Selling a bunch of parts off my 91 Camaro drag car. All parts in good shape. All parts are for sale or for trade. Will trade all parts listed for an extended or crew cab silverado or street car. Let me know what you have all I can say is no. Can text you pictures of everything 859-663-1114 located in Walton ky
Aje tubular k member with pinto rack, set up to me used with motor plate. Aje tubular a arms, 2in drop spindles with Aje coilovers and caster/camber plates. Complete with willwood street strip brakes. $2000 for complete setup
12 bolt rear with adjustable torq arm set up. Moser axles, c clip eliminators, spool, 308 rear gear as well as will include a 456. Has drum brakes on it currently but I have an ls1 disk brake set up I will include as well. Rear will also come with qa1 coilovers. $2500 for it all with coilovers and torq arm.
Built turbo 350 with trans brake, reverse valve body. Trans has been 9.90s Behind a bbc and has seen street use. Ptc 9.5 in converter 3000 stall set up for LS so you do not need an adapter.
$1300 for trans and converter will separate or trade for a t56 setup
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Complete tubular k member set up, 12 bolt, turbo 350 with brake
Theoretically and seriously what would you do for everything front end rear end and trans
no problem
Terrell351
06-13-2021 01:13 PM
