[FL] Holley Commander 950 ECU
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... SOLD ... SOLD ........ Holley Commander 950 Engine Control Unit with MPFI harnesses to plug n play on TPI L98 and LT1 motors ... converts MAF to speed density ... uses all GM style sensors ... includes ECU , Main harness , V8 Fuel Injector harness , Communication cable with serial to USB adapter ... Tune on the fly with a laptop ... full control of Fuel and Spark ... also includes 114 page installation and tuning manual ... software is available free @ www.Holley.com ..... including base maps ... Holley tech service is awesome even on Saturdays ....... $550 shipped to the lower 48 .........
Car: '87 Vette C4
Re: Holley Commander 950 ECU
..... Still Available ...............
Car: '87 Vette C4
...... Oh Yeah ! ..... Worked great ! ... what a blessing to tune compared to the erase and burn headaches of the OEM stuff ... I'm upgrading to the Holley HP to compensate for some major mods and to get a few more I/O's and options .............
Car: '87 Vette C4
..... No limits ... Some apps may require additional hardware that Holley offers ... i.e. : 16 or more injectors requires additional drivers .... there are base maps in their library for 502/502 Big Block Chevy engines ... and Alpha-N base maps for engines with extreme overlap camshafts (over 245* @ .050) ... Base maps for MPFI are available for engines using up to 50lb injectors and cams with up to 245 degrees of duration and Forced Induction ..... Its a VERY flexible/adaptable system and will go well beyond the base maps ........
Car: '87 Vette C4
........... FREE Shipping ! ...................
Car: '87 Vette C4
........... Still Available ! ..................
Car: '87 Vette C4
..... Pretty much ... Just remove/disconnect your MAF ... add a MAP sensor ... plug the Holley harness in to the engine's sensors , distributor , and fuel injectors ... connect some power wires (run the main power and ground directly to the battery) ... load up a base tune and follow the instructions from there ... Installation and tuning instructions are included and are written in plain English .......
Car: 91 ws6
Engine: Carb'd 334 stroker
Assuming then that it'd work on a 305 and 350, with different tunes of course. If so, definitely interested. I want to keep my tpi when I go 355, also want SD on current 305 + the 355
Car: '87 Vette C4
...... This particular kit has a V8 fuel injector harness ... it will run any V8 with the early fuel injector connectors ... Tuned Port , LT1 , HSR , Ford , etc. ... harnesses and connector adapters are available to fit most any other application ... all you need to add is a laptop computer and a GM MAP sensor ........
Car: '87 Vette C4
..... The 950 ECU does not connect to the speed sensor ... just leave your factory ECU in place and wire the Holley to your engine and its sensors ... you can deal with the factory engine harness any way you wish ... I left mine in place for several reasons ... I did not get an SES light ....... Its really easy ......
Car: '87 Vette C4
Car: '87 Vette C4
............. ... SOLD ....... ................
RedLeader289
05-28-2019 01:47 PM
KO1
16
10-15-2015 05:00 PM
Royal_Z
09-30-2015 08:45 PM
