[GA] Motorsport Tech 1.75" Thick Wheel Adapters, Hub & Wheel Centric
This is a pair of brand new Motorsport Tech wheel adapters. They're 5x120 bolt pattern, 1.75" thick. They're both wheel and hub-centric and have 12mm studs.
They're annodized black.
$150 shipped.
$150 shipped.
Car: 1992 Formula 350
Engine: 5.7 L98
Re: Motorsport Tech 1.75" Thick Wheel Adapters, Hub & Wheel Centric
let me ask a stupid question. As you stated these will allow the use of 1994 and up wheels? So I would imagine you would need four for all wheels?
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
If im upgrading to c5 bug brakes and i run the 2 inch spacer upfront will the new set up be .25 bigger? Like itl stick out further? Im getting the c5 kit tomorrow and im interested in the hubs possibly if that what i stated is true
Car: RS Camaro
The C5 Z51. I was told they can fit under 17 inch wheels. I'm using the y2ks wheels set. I may switch brackets to the non Z51 but if they will fit under my 17s I won't.
Car: RS Camaro
The Y2ks is what I meant through the blabbering.
Car: RS Camaro
Since you are changing the front hubs doesnt that mive it out .300? Give or take some
