Small block parts
1 Post
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Small block parts
I have a bunch of small block parts for sale, all prices are best offer.
2 factory T5 transmission crossmembers
B&M ripper for a T5, boot is included but torn.
SLP 1-5/8" headers with custom y-pipe (will cut to ship in a smaller box). One of the air tubes is broken, I can weld it back if needed but it won't look like a factory weld. Also, the headers are stainless steel but the y-pipe is mild steel.
Not sure how this dent happened, but it's there.
***Also 1 of the air tubes is cracked at the #2 primary, has to be welded shut. I can weld it back if you want***
Centerforce I clutch with GM lightweight flywheel, comes with ARP hardware.
Comp Cams 1.6 roller tipped rocker arms.
1 Post
Car: '88 Formula
Re: Small block parts
Here are some new unused parts I never got around to using.
Power steering pump
Tensioner
Power steering pump
Tensioner
1 Post
Car: '88 Formula
All prices are best offer, if you want a shipping quote also please include your zip code.
1 Post
Car: '88 Formula
TPI intake, pre-'89 with 9th injector (but the hole is filled with a freeze plug, not sure if I'll be able to find the injector itself, fuel rail is a newer year so no plug to leak), comes with hardware can get pictures if needed.
LT1 intake
Performer intake
LT1 intake
Performer intake
9192camaro
16
02-03-2019 12:21 AM
theshackle
03-05-2017 06:37 PM
Fast355
12-02-2016 06:33 PM
