[IN] Lots of fuel, ignition, and sensor parts from 1992 L98 Trans Am
These were taken off my personal vehicle after a flaw in the torque converter caused it to bulge out of shape and destroyed my entire drivetrain. Bizarre and rare issue for a stock vehicle and completely undetectable until it had already destroyed the rotating assembly. Been busy building basically a brand new L98. I wanted to see if anyone was interested in buying any of these good used parts off of me. Car had exactly 100,000 miles on it when this occurred and had been garaged and well maintained for most of its life. All of these are OEM parts. Car ran flawlessly before the torque converter killed everything.
I am also looking to buy a set of nice 91-92 Trans Am tail lights without ANY signs of delamination. Might as well put that here...willing to make a fair deal on them.
Brand new Sealed Power brand gasket set for entire intake.
Brand new AcDelco fan switch pigtail with splicing kit.
Late year/ 1LE fuel sending unit w/ good fuel pump and extra hardware/gaskets: Would like around $100 for this
8 OEM injectors for 92 L98, 2 are later design to replace 2 bad ones. Would asking around $100 for these and the other fuel stuff be crazy?
OEM fuel pressure regulator and aluminum mounting plate and fuel pressure valve
Nice set of 8 of the OEM packard numbered spark plug wires
OEM TPS- SOLD
OEM coil
OEM ignition control module
OEM distributor minus gear
EGR valve
Vacuum valve for the passenger side part of the plenum that connects 3 vacuum lines
Valve for the charcoal filter
OEM MAP sensor
OEM metal oil pressure sensor- SOLD
OEM IAC valve - SOLD
OEM knock sensor -SOLD
Every OEM temp sensor (coolant, air, fan switch, etc.)
OEM 02
"Silencer" muffler thing for the air pump system
Set of 8 AcDelco professional platinum plugs with less than 1000 miles on them, these are the ones with the platinum on both ends.
If you buy the fuel sending unit I can pack almost everything in the box with it so if you want some extra parts you'll be saving on shipping.
Make me some offers, would prefer payment over Paypal for everyone's sake.
OEM TPS- SOLD
OEM coil
EGR valve
OEM MAP sensor
OEM 02
Re: Lots of fuel, ignition, and sensor parts from 1992 L98 Trans Am
I have a mostly complete distributor. We ended up building a new one. The one I have is now missing its gear, and missing the inside "shelf" that the pickup sits inside, but everything else is there.
Lots of this is still available, make me offers if you want something, the more you buy the more you save.
Car: 87 GTA
Transmission: Automatics
Are any of the items still available? I pm'd u last week..
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
1992 Trans Am
08-09-2015 04:32 PM
