[MI] 350 build part out, MANY sbc parts
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Hey All,
I sold my Camaro and am going to be doing an LSx swap on my car.. so I will be selling off all of my Gen I SBC parts.. I am going to try and get back to everyone as smoothly and quickly as possible.. the larger items I would prefer not to ship, but might be willing to put in the back of my truck and meet up somewhere if you are close enough (you pay gas of course).. I would actually prefer everything be pickup only.. but I know that won't be the case.. so if it needs to be shipped I will work with you on that.. so all the listed prices are WITHOUT shipping included.
ask any questions and I will try and get pics up.
350 long block engine - SOLD
- .040 over flat top hypereutectic pistons
- .010 under crank journals
- Moly rings
- Bimetal bearings
- High volume oil pump
- ARP fasteners
- stock rods/crank
- Heads (L05 rebuilt and milled slightly, with Crane Valve Springs.)
- Proform timing chain cover and cam button
- F-body oil pan
- Comp Cams Thumpr Cam (279TH7)
- Comp Cams Lifters (came w/ Thumpr Cam)
- Proform gear drive
- Summit One piece forged chromemoly pushrods.
- Crane Gold Race Full Roller Rocker Arms (1.5, non self aligning, narrow body, extra cost if wanted)
700r4 Transmission - $375obo (not immediately available)
- Stock converter
- New filter and fluids
Summit Racing Street & Strip Stage 1 Intake Manifolds SUM-226016 - $115obo
- needs cleaning up some
MSD Pro-Billet HEI Distributor (8365) - SOLD
- very low usage
- still have original box with springs and weights
Holley 670cfm Street Avenger (0-83670) - SOLD
- may need going through at some point
- polished aluminum
- comes with fuel rail with fuel pressure gauge
Holley High flow fuel pump, with pushrod and mounting plate - $100obo
- used in working condition
Hedman Elite HTC headers (68476?) and y-pipe (17478) - $375obo
- slight surface rust on headers
- y-pipe is rusty but still usable, was painted black but burned off
Trans-Dapt oil dipstick kit (8142) - $30obo
Proform Black Valve Covers (141-131) - $100obo
Holley throttle bracket (HLY-20-95) - SOLD
Holley kickdown bracket (HLY-20-121) - $15
K&N drop base air cleaner (KNN-66-3040) - $90obo
B&M torque converter 700-r4 lockup kit (B&M-70244) - $150obo
B&M Megashifter kit (B&M-80692) - $175obo
- used, no box
- some parts show wear, but still very usable
700r4 Transmission cooling lines (custom made by fine lines inc) SOLD
700r4 Drive shaft - $50obo
700r4 Torque Arm - $90obo
Summit high torque mini starter (SUM-820323?) - $150obo
L98 Serpentine Kit - $300obo
- both brackets
- power steering pump
- alternator
- pulleys
- water pump
SBC gen 1 generic HEI distributor msd knockoff - make offer (PENDING)
Carter mechanical oem style fuel pump - make offer
70's Truck quadrajet carb, needs rebuilt - make offer
Cast iron quadrajet intake, manifold bolt holes were slit to work on later style heads - make offer
Stock stamped steal valve covers - make offer (SOLD)
- Moly rings
- Bimetal bearings
- ARP fasteners
- stock rods/crank
- F-body oil pan
- Stock converter
- very low usage
- polished aluminum
- used, no box
- both brackets
- alternator
- pulleys
- water pump
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
Re: 350 build part out, MANY sbc parts
Are trans cooling lines new or used ?
1 Post
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
How much for the oil pan shipped to 42303?
Engine: HO 5.0
Trans lines were new when I bought them.. but are now used.. only a few years old. still look very good.
I would prefer not to separate the engine if possible.
Car: 87 Iroc Z 28
Are trans cooling lines for stock replacement. I have a 700R4 and want to replace the lines. Are the fittings for trans and radiater on lines. I am in Dearborn Hgths Mi. and could possibly pick up. Where are you located? Is serp set up for passenger or drivers side alternater ?
Engine: HO 5.0
the serpentine setup has the alternator on the drivers side.
Car: 87 Iroc Z 28
Where in SE Mich are you ? Would like to get lines. How old is the 670 Holley, any chance of posting pick of carb and lines ? Thanks
Engine: HO 5.0
I'll just took pics.. Lemme try and upload
Engine: HO 5.0
Car: 87 Iroc Z 28
I would like to come out next week and pick up trans cooling lines, consider them sold. PM me with contact info so we can set up a day and time.
Car: 91 RS
Engine: Built 383 Stroker
Transmission: Turbo 350 3500 stall
Axle/Gears: Stock
Serpentine setup still available? Picture?
The hood I bought from you worked great.
Engine: HO 5.0
bump with updates and I'll post a few more pics today!
