[Sold] Brand new zz4 heads
Brand new zz4 heads
Nos zz4 heads, unassembled with Manley valves, guide seals, 7/16x3/8 studs. Zz4 spring and keepers,locks good upto .530 lift no machine work needed. $950 shipped in the lower 48. All these need is to be assembled and the valve springs installed to the recommended install height .alex springs has the spring shims.
Car: 1987 Camaro
Engine: 383
Axle/Gears: Working on that
Re: Brand new zz4 heads
Interested! Still got them? Are these close to or the same as the fast burn heads?
Car: 1987 Camaro
Engine: 383
Looks like you are in the Denver area I am north of you in WY. Drop me a line on these. Looking for a good set to use on a vortec build I am getting ready to start.
Pm sent, I'm in Cotopaxi ,co but I do goto Denver every few weeks.
Zz4 hardware installed to accept more lift over the 981-16.
Installed height checked and within 1.78 +.020-.040. There are no thinner locaters avaliable stock is .020.
Flow numbers unported
intake
0.05 30.18
0.1 58.23
0.15 90.440002
0.2 116.599998
0.3 158.360001
0.4 185
0.5 193.139999
0.55 193.139999
exhaust
0.05 22.780001
0.1 47.330002
0.15 70.419998
0.2 94.010002
0.3 126
0.4 144.960007
0.5 160.589996
0.55 162.179993
intake
0.05 30.18
0.1 58.23
0.15 90.440002
0.2 116.599998
0.3 158.360001
0.4 185
0.5 193.139999
0.55 193.139999
exhaust
0.05 22.780001
0.1 47.330002
0.15 70.419998
0.2 94.010002
0.3 126
0.4 144.960007
0.5 160.589996
0.55 162.179993
58cc
Fastburn specs
http://vi.raptor.ebaydesc.com/ws/eBa...=1427883043530
Zz4 specs
http://m.summitracing.com/parts/NAL-12556463/
Car: 1988 Iroc Z
Engine: 5.7
Axle/Gears: 9 bolt 2.77
Man would I love to have these but I have to ask and please pardon my ignorance, are they smog legal? I live in CA and if I remember correctly I need exhaust crossover for EGR function. Correct?
Engine: 4++,350 & 305 CIs
I have told a few people about them.
3rd and 4th pic. In the 4th pic the valve stem points right at it. without machining those flat, that ding will prevent the head from sealing. Like I said, Im not trying to be a jerk, But I see that ding as a huge deal. Especially dealing with aluminum and its expansion rate vs cast/iron/steel. Must be perfectly flat, or you will have sealing issues. Is price negotiable?
86IROC112
08-17-2015 02:00 PM
