LT1 intake conversion and Holley Commander 950
Car: 1985 Trans Am
I have for sale the EFI setup that I intended to go on my 85 TA, but I am changing directions. Everything shown has never been used. It is a converted LT1 intake, with rails and hoses for a TPI car. It has added material around the water crossover ports along with being port matched to a fel-pro 1905 intake gasket, for 190-200cc heads. The conversion was done by welding, not epoxy. I am also including an Accel dual 58mm billet throttle body with TPI style throttle linkage. The distributor is an MSD Pro-billet external coil HEI style, with coil included. I have included the proper AC delco pigtails to use the distributor with the Holley commander 950 setup, which is a TPI style harness. Again, everything is new, and I am including the extra round-style MSD coil and conversion cap in the white box that allows for using the round coil with an early HEI. I am not looking to separate at this time, I've had it for this long, I suppose I can be patient. I also have a few other SBC performance parts to sweeten the deal if necessary, such as pro-magnum rockers. Make reasonable offers for everything please, offers.
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: LT1 intake conversion and Holley Commander 950
I would be interested in the intake, tb, and linkage for another project I have going if you decide to split it up. Just PM me if you decide to do that.
1 Post
Car: 1987 Pontiac GTA
Engine: ZZ4 350 W/ HSR
Axle/Gears: 9 Bolt 3:45
I know you said you wouldnt separate but sounds like dellman83Z is interested in some stuff and i am interested in the other.
Please let me know if you decide to separate also
1 Post
I have a Holley Stealth Ram intake with the Holley Fuel rail and southbay injectors. I basically am just looking for the commander 950 and TPI harness.
86IROC112
08-17-2015 02:00 PM
