kansas spring shop cleaning
Car: 91 ws6
Engine: Carb'd 334 stroker
Cleaning out shop for spring!
everything is just taking up space, so not looking for top dollar.
what I have (that I can immediately find)
-Rear springs from an 85 t/a. $30
-air con system from an 87 t/a, with brackets $30
-air pump from same car. Squeaky, but works. $20
-1300 shall stock converter for a 700r $20
-Complete 4x4 4l60e, reverse is kaput from 01 blazer $100
-Np233 t-case, told it works but never tested. Out of 01 $75 blazer
-gas tank from an 85 bird. Could use cleaned inside. $40
-Wrap around Wing from an 85 bird. Paint is shot, and the arms are flimsy $45
-wrap around wing from an 87 bird, third light. In very good shape, minus paint. $65
-sbc starter, works fine $20
-black front hood vents, paint sucks $10
-anything under the hood in the pic. 85 t/a, auto, 4 wheel disc car. Harness is botched. Entire braking system there and good,
wiper motor there and good, p/s pump, other misc stuff. $???
-tail lights from an 85 t/a. Tinted but otherwise in good shape, no cracks $75
-drivers side bird glass $30
EDIT: TPI intake, harness, dizzy, ecu and all sensors for sale.
305 maf car, ecu has hyper tech chip. Maf and all sensors are good, had no check engine lights.
Harness is in good shape, with the exception of the bit that connects to the dual fans. That was botched and set to run on manual dipswitxhes when I got it.
Asking $300 for everything
-l98 083 steel heads. Rebuilt, stock rockers and valves, milled .01, no porting $300
-a/c compressor and lines. Intact, dunno if worked, was out of r12 when I got the car $30
-washer fluid tank $10
-heddman shorty headers $75
Prices may be flexible. I'm still finding more stuff as I clean/decide what I want to let go of. All prices are + shipping,
pm or call/text 316-217-1240, I dont quite have pics of everything.
Car: 91 ws6
Also adding my tpi setup. Going Ls, so I recon I can let this go.
Will be pulling the harness and ecm from the car shortly. They can go with.
Manifold came off a running car, in good shape. Dirty, but worked fine. Vac lines are cracked. Can come with dizzy, harness, ecm and maf.
harness is in good shape, comes with all the relays and such. Only damaged spot is where the fans connect in, it was butchered when I got the car, wired for toggle switch fans.
Asking $100 for intake, or $300 for the entire shebang
Car: 91 ws6
Yeah, I would, $50+ shipping
Has hyper tech thermo master chip. Chip alone is $200 new.
1 Post
Car: 2014 cruze and 1987 trans am
Engine: trans am=5.0
Transmission: auto
Re: kansas spring shop cleaning
i could use the t/a tail lights and the rearview mirror from the car, let me know a price and possibly shipping to 21875
sailtexas186548
08-26-2015 03:32 PM
