[VA] 383 stroker all forged built for boost
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Selling my short block or long block. Short block consists of 4 bolt roller 350 bored .030 over and clearance for 383 stroker ARP main studs scat crank eagle h-beam rods srp low compression forged pistons all balanced and blue printed high volume oil pump mildono 7qt oil pan custom grind hydraulic roller turbo cam by comp cams. $2500
If interested in the long block it has cometic 3 layer head gasket with ARP studs dart iron 200cc heads fully ported and polished with upgraded springs angle plug heads comp can pushrods and custom fabricated valve covers.$3000
. Compressions is at 8.5:1 so this setup can handle some boost. I have the receipts for everything including machine work
Located in virginia
Located in virginia
Re: 383 stroker all forged built for boost
Bump
Bump
I can provide cam specs and any other specs if interested. I will even throw in a basically new msd distributor and msd 6al-2 digital programmable box and msd plug wires
Bump make offers
Andrew Prakash
09-08-2015 11:48 AM
