Cheap 305 TBI stuff
Car: 1989 RS, currently bone stock
Engine: 305 TBI
Transmission: Th700R4
Axle/Gears: None at the moment, bad accident
Cheap 305 TBI stuff
Was going to pull my intake manifold on my L03, ended up cracking it and spilling coolant everywhere. Took it as a sign to go ahead and swap the engine
Anyways, if anybody needs any L03 engine components, post here and ill let you have it for cheap. Just trying to make a little $ to finish up my swap, and i wanna sell this stuff fast. The (almost complete) motor has 56k original miles and ran just fine until i parked it a few months ago.
Main stuff for sale:
Air cleaner assembly (single snorkel)
Freshly rebuilt TBI
Valve covers
Complete cylinder heads (selling as pair)
Cam
Timing assembly
Oil pan/pump
Block + rotating assembly (would like to sell together, don't have to)
Once I start to break stuff down, if i find things that may have been damaged due to any coolant that I couldn't drain, Ill let it be known below.
I'm surely leaving out random little things (like lifters), but if you need specific stuff, just ask on here or PM me. You can come pick it up (Wilmington, NC), or pay me to ship it to you. I'll clean everything (the best I can by hand) before I sell it. Thanks
Freshly rebuilt TBI
Valve covers
Cam
Timing assembly
Oil pan/pump
Engine: 305 TBI
Re: Cheap 305 TBI stuff
Just to be clear, I have no set prices, make me an offer, I'll sell it cheaper if i can get rid of it faster, I would like to finish my swap before the middle of June.
Engine: 305 TBI
I'm honestly not sure, I haven't shipped a motor before, I usually do local stuff. I'll look into it.
About 700 miles between us, but I don't have an accurate weight for a short block 305, I'm assuming it's about 250lbs, which gives shipping estimates of about $400.
Car: 1988 Camaro
Here is some idea on weights.
block 148-155 lbs
Crank 50-55 lbs
Rods and pistons 5 lbs
Oil pan 6 lbs
block 148-155 lbs
Crank 50-55 lbs
Oil pan 6 lbs
Engine: 305 TBI
Thanks for the weights, shipping should only be $320ish. TBI unit has been sold.
