[NJ] LOW low miles LS1 with full boltons/M6
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
It's time to move on from this project.
The block has 91 miles, bought brand new and added the H/C/I to it before firing it up. Trans has as many miles from a fresh rebuild too.
I will sell it as a complete setup or just the long block. headers/K member could be included too. Make me an offer.
Engine: $3000
Brand new LS1 (trip odo is actual engine miles)
-FAST 92MM intake
-FAST 92MM TB
-Futural F13 cam
-Patriot Stage 2 CNC ported heads
-42lb injectors
-High flow oil pump
-Double roller timing chain
-New water/PS pumps
-New high amp alternator
Trans: $2000
Freshly rebuilt T56
-LS7 clutch
-New slave cylinder
-4th gen aluminum drive shaft
-GTO shift ****
Pics: https://drive.google.com/folderview?...Xc&usp=sharing
Engine: $3000
-FAST 92MM intake
-FAST 92MM TB
-Futural F13 cam
-42lb injectors
-High flow oil pump
-New water/PS pumps
Trans: $2000
Freshly rebuilt T56
-LS7 clutch
-New slave cylinder
-GTO shift ****
Want a title? Post!
Car: 46 Chevy truck
Engine: 355
Axle/Gears: 342
Re: LOW low miles LS1 with full boltons/M6
interested in the engine,, what brand is the block and is std. bore, comp. ratio,, head cc, is the oil pan included and if we make a deal would you beable to meet me say half way,, maybe Harrisburg PA.,, I live in central VA.
Thanks for the info,,, Allan
NBrehm
08-25-2015 11:49 PM
GVMV
08-16-2015 08:01 PM
