[VA] Stealth ram compleate
Car: 92 z28, 91rs vert, 2015 1le
Engine: Bolt on ls2
Axle/Gears: 4:10:1
For sale is a holley stealth ram complete fuel injection system for small block chevy.This is the avenger hp system and includes twin 58mm tb, polished upper intake and standard finish lower,all sensors with 1 and 2 bar map sensor,kirban billet fuel regulator,hand held controller for self learn(1 bar map only), 36# holley injectors, street fire msd box, coil, and distributor,lokar throttle cable, 100psi fuel pressure sensor,complete harness, usb cable for tuning with any windows computer(if self learn disabled).I have a vortec or standard pattern base which ever you want.This system is in perfect working condition and will make any carbureted car feel like crap. THIS SYSTEM USES WIDE BAND O2 SENSOR(included)this is a turn key fuel and ignition system minus fuel pump.Sells new for $3300+ and does not include usb cable,fuel sensor, any ignition items, throttle cable, 2 bar map sensor or boost/vac regulator. ASKING2400 obo would prefer to deal local and in person.I'm in richmond vs.please pm me for any additional info and I'll get back to you asap
Engine: Bolt on ls2
Axle/Gears: 4:10:1
Re: Stealth ram compleate
Just let me know what you are interested in and maybe we can come to a deal
Engine: Bolt on ls2
Axle/Gears: 4:10:1
I'll keep that in mind if it doesn't sell soon
Engine: Bolt on ls2
Axle/Gears: 4:10:1
Here's a pic of the stealth ram not the best quality pic but a very clean setup.
Car: 1988 Iroc-Z
Let me know if you part out. I might be interested in just the stealth ram upper and standard lower intake base and nothing else.
1 Post
Car: 1985 camaro iroc z-28
Engine: 5.7L
seems like you have a buyer for the base, a buyer for the wiring, and ill take the ignition for a deal. i have the set up but having issues on getting it running. if you could reply to see if you could help as you had the set up.
Car: 1988 GTA Trans Am
Engine: 5.7
Interested in the Stealth ram and fuel rails. If not available how much for the 58mm?
I'm interested in the manifold and fuel rail
Looks like a old dead thread. You might try here for a hsr.
https://www.thirdgen.org/forums/engi...ealth-ram.html
Car: 1991 Chevy Camaro Z28
Here is another variation I recently came across. I have purchased the parts but not yet fit it all together to test it, but it looks like it will all work:
-4an 90 degree female/female https://www.ebay.com/itm/263500052404
-4an male to 1/8 npt female
