HSR Manifold/Plenum
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
HSR Manifold/Plenum
Just took orders to Japan and trying to clean up the garage. Looking to get rid of my old HSR Manifold and Plenum. This one is the original casting with a brand new plenum (kept my old plenum since it was polished and painted). I upgraded heads and needed the larger ports of the newer version manifold. Nothing wrong with this one. Would like to get $200 plus shipping. pics coming soon.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Re: HSR Manifold/Plenum
The newer one has larger ports and more "meat", so you can port it to a larger runner; i.e. I could not port this manifold to the runners of the AFR 195 Eliminator heads I bought, not enough material to seal correctly. This one takes the smaller FELPRO gasket (IIRC).
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Of course, it's designed for it! When you start going for bigger ports to increase flow it becomes a concern. This manifold would have worked on the AFR 195 Eliminator heads I bought, but I wanted to port match the manifold to the head for improved flow and this early casting did not have the "extra" meat to allow for porting and still seal correctly. If you're not going extreme, this manifold will support up to 6500rpm on your motor, with the right head/cam combo.
My engine has stock internals with external bolt ons. Looking to get better performance than the stock TPI. I'm planning on doing a cam change and using the vette 113 heads. What else would I need for this intake? Rails intake etc?
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Stealthram92z - I'll do $250 shipped to WI.
91chevyz28 - Same, $250 shipped to lower 48.
LMK...
LMK...
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Pics of the Holley 52mm Throttle Body. Just so I don't misrepresent, the linkage on the Holley 58mm Throttle Body I purchased for my upgrade would not work on my 1990 700R4 setup, so I swapped linkages. I believe the linkage on this one is for a standard transmission. I swapped the rod and TB Plates (butterflies) only.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
I still have both items. I'm waiting to hear back from stealthram92z regarding the manifold/plenum.
I'm waiting to hear back from 91chevyz28 regarding the Throttle Body.
If no response, I'll go down the list to move these items. Let me know...
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Holley 52mm Throttle Body is available for $250 shipped.
stealthram92z - Like I said several posts above, $250 shipped.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
HSR Manifold/plenum sold. I still have the Holley 52mm TB available for $250 shipped to lower 48.
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
Thanks Magman, let me know when it ships.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
HSR manifold and plenum were shipped to you on Friday via UPS Ground. My wife left the tracking number at work, but I'll get it you on Monday. Expect approx 7-days. Hope you enjoy and good luck with your build! Thanks.
~Magman
~Magman
86CamaroDan
09-29-2015 10:08 PM
