[ON] 9 Bolt Axles Partout
Car: 1991 Camaro RS
Engine: 305 will be LSX eventually
Axle/Gears: Borg Warner
Re: 9 Bolt Axle with 4.10 Gears
I'd be interested in just the gears sets you have if any of them are 3.7 or numerically higher. Come November if you decide to part them out, PM me if you decide to do that.
Complete 9 bolt Borg Warner axle with 4.10 gears.
Fully rebuilt about 2,000 miles ago with all new bearings & seals & longer studs.
TA Performance cast aluminum rear cover (pre-loads main bearing caps).
Ratech solid pinion spacer.
Housing has lower control arm relocation brackets installed/welded on.
Posi is fully shimmed and works beautifully.
Comes with backing plates for single piston rear disk, no calipers, disks, or brake lines included.
This axle will bolt into any thirdgen with no modifications.
Will crate axle if shipped.
Located in Ottawa, Canada.
Shipping extra - approx $200 via freight to almost any USA.
How much for the rear axle?
GEARS & BEARINGS:
-370 NEW IN BOX GM9-370 Motive gears ($225 new) $175 [SEE OTHER POST FOR DETAILS https://www.thirdgen.org/forums/engi...lt-3-70-a.html
-Complete NEW IN BOX Master Install kit (have 2) - Motive R7.75RMKT ($162 new) $100 (Timken carrier and pinion bearings, carrier and pinion shims, bolts, rtv, marking compound)
-327 used gears $40
-410 used gears $150 [SOLD]
AXLES:
-Axles - $50 pair with bearings & seals & retainers (have 3 pairs, plus one other, not sure what side) [SOLD 2 PAIR & EXTRA - 1 PAIR LEFT] - shpping is about $40 for a pair
DISC BACKING PLATES:
-Backing plates for single piston disk brakes - $40 pair (3 pairs, 2 with dust shields, 1 without) [SOLD 1 PAIR - 2 PAIR LEFT]
POSI CARRIERS:
-'3' Series Carriers $200 with tight posi cones, lots of wear left (have 3) [ALL SOLD]
STUD GIRDLE:
-TA Performance Rear End Girdle with optional ARP studs $125 [http://www.taperformance.com/proddet...?prod=TA_1802] [SOLD]
HOUSINGS:
-2 housings with lower control arm relocation brackets welded on - offers [SOLD 1, 1 LEFT]
-327 used gears $40
AXLES:
POSI CARRIERS:
STUD GIRDLE:
HOUSINGS:
Car: 89 GTA/89 GTA
Engine: L98/lt1
Transmission: 700R4-
Axle/Gears: 3:27/3:73
Re: 9 Bolt Axles Partout
What's the total on the 3.70 gears and install kit shipped to 19020?
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
hectre13
08-26-2015 08:17 AM
