[PA] 85-92 Camaro parts
Old 10-09-2015, 06:42 AM
bamaboy0323's Avatar
85-92 Camaro parts
I'm not sure what happened to my previous post so I'm posting it again.
Prices are all picked up locally, shipping will be more.
OEM Springs-$20
1992 Camaro Factory hood. Has a little bend on the edge but looks fixable $40
1987 MAF Prom ABWN 8656(350tpi w/auto)-$30
165 ECM-$30
746 ECM-$30
158 ECM-$30
TPI Plenums-$30 a piece
TPI Runners-$30 both
TPI Intakes-$40 a piece
TPI Fuel Rail w\ 19lb injectors-$30
TPI Throttle Body w/sensors-$30
MAF wiring harnesses-$25
083 & 217 heads-$50
TBI Harness Complete-$75
Valve Lifter Guides-$20
Lifters, Cam, pushrods(all stock I believe)-$100
Dash harness-$30
TPI setup from 85-86-$80
Pics available upon request
Old 10-11-2015, 12:20 PM
sahlomonic's Avatar
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
Re: 85-92 Camaro parts
Location? What color hood?
Old 10-11-2015, 04:58 PM
Blue but needs repainted. Carlisle, pa. Hood will come with no hinges or hood latch or insulation pad.
Old 10-11-2015, 08:08 PM
Pics updated
Attached Thumbnails 85-92 Camaro parts-2015-10-11_17-39   85-92 Camaro parts-2015-10-11_17-40   85-92 Camaro parts-2015-10-11_17-40
Old 10-23-2015, 06:31 AM
Bump.....
Old 10-23-2015, 08:21 AM
Lasroc90's Avatar
OEM Springs-$20
165 ECM-$30
746 ECM-$30
158 ECM-$30
083 & 217 heads-$50
Dash harness-$30
Is the tpi throttle body in good shape? Will it work on a 90 350 .
Old 10-25-2015, 05:59 PM
No, the only TB I have is for 89 and older TPI's. Sorry
Old 10-29-2015, 11:28 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
what year is the tbi harness from, as well as the dash harness?
Old 10-30-2015, 06:00 AM
I will look when I get home this evening.
Old 10-30-2015, 01:49 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
thanks.
Old 11-01-2015, 10:53 AM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
what did you find?
Old 11-01-2015, 11:22 AM
what did you find?
Pm sent
