[NH] ZZ4 Top end (heads, cam), 4bolt 355 in bag
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I bought this stuff for one of my Corvettes. Well, the frame on my '79 is too gone to be repaired and since it had the built motor that's going in my '75.
So I've got these ZZ4 heads and cam sitting around collecting dust.
The heads are polished. I didn't do that, but what I did do was replace all the springs with brand new GM performance parts 12495494 springs. (LT4, ZZ4) and 19171528 retainers.
$600 for the heads and cam, plus shipping.
I've also got a 4 bolt main, roller block. 1994 casting. Was hot tanked, magged, bored .030 over, brass freeze plugs, cam bearings, etc. $600
I don't think I can ship the block, but if I did, buy pays shipping.
-- Joe
-- Joe
Re: ZZ4 Top end (heads, cam), 4bolt 355 in bag
-- Joe
-- Joe
Any chance you sell the cam?
Mikeymorris3@gmail.com
Engine: 4++,350 & 305 CIs
Separate the cam ?
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
Were the heads Redone and if so about how long and what do you want for them
I then decided to buy the LT4/ZZ springs, retainers. The springs I bought have more spring pressure than the older ZZ4 springs.
PM me an offer if you are still interested.
-- Joe
1 Post
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Interested in the heads, since I already have the cam. Just want to clarify a few things. What's the max lift on those springs? Would I be able to throw some 1.5/1.6 split ratio roller rockers on without a problem? Are they ready to install, or is work needed?
Coil bind is 1.220"
So that's .560" lift at bind. I'd allow .030" for clearance.
ZZ4 cam is .470" at 1.5, .501" at 1.6.
The heads are clean and ready to run. I actually have not put the new springs in, (old ones are still on) they are new in box but I'll do that if someone wants to buy the heads. Or perhaps someone will want to buy them without the new springs + retainers at a lower price.
-- Joe
1 Post
Engine: 355
Transmission: 4L60
I gotta check the install height, but I think it's around 1.780"
Coil bind is 1.220"
-- Joe
Coil bind is 1.220"
-- Joe
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Are these the aluminum fast burn/vortec ones? There a number on them? Got any pics? Id be intrested in them w/o the cam.
1 Post
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Do the heads flow more than stock Corvette 113's?
Heads sold. Thank you!
-- Joe
-- Joe
Let me know if the cam doesn't sell
92rsvortec350
02-22-2016 09:32 PM
yellowferrari
10-12-2015 11:07 AM
ambainb
10-10-2015 08:19 PM
