F.A.S.T. Classic stand alone ECU and harness
Old 01-30-2016, 05:08 PM
BOTTLEDZ28's Avatar
Transmission: A4
Selling a FAST Classic bank to bank wide band stand alone ECU setup for TPI engines. Comes will harness, ECM, COM cable, software CD and Ill even give you the laptop I used to program and tune with. This setup cam out just prior to the newer XFI systems. I picked up 99rwhp using this setup over the stock computer and memcal tuned by Fastchip. The harness comes with all pigtails and connectors as well as a few extra circuits. (fuel pump and fan control).
If youre interested then Id suggest contacting FAST to get the details pertaining to the system. THeir site does not list any details pertaining to the Classic system. I paid almost $3K for this setup back in 2005. It had extra stuff done to it like dual stage nitrous add on as well as the wide band O2 sensor. Asking $650 plus shipping.
Old 02-01-2016, 08:06 AM
Mrich0908's Avatar
Re: F.A.S.T. Classic stand alone ECU and harness
Im interested and live close.
Will this system work with ls1 type motors? I have EFI connections 24x system for my sbc.
Old 02-03-2016, 09:19 AM
BOTTLEDZ28's Avatar
Transmission: A4
I am not sure. You would have to contact FAST and see what they say.
Old 02-18-2016, 07:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
TTT
Old 03-03-2016, 12:10 PM
haro_is_king's Avatar
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
How did you pickup that much rwhp with this?
Old 03-03-2016, 12:46 PM
BOTTLEDZ28's Avatar
Transmission: A4
I was trying to run a 383/HSR/AFR195 engine with the factory computer. I did have a Fastchip piggyback chip running it and it ran ok but I knew it had more in her so I found this setup at my local tuner. I bought it off him and he guided me through a few steps to get the car running good enough to drive it to him. He tuned the car in the middle of August with 90 degree temps and 100% humidity in the shop and picked up 99hp over my previous dyno run with the factory ECM.
Everyones results will vary though
Old 03-03-2016, 01:59 PM
So this replaces the stock ecm (under dash), are the burned chips still used or does this standalone have something to use in place of the chip?
Old 03-04-2016, 09:47 PM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
Just curious if this requires the harness or if the factory TPI harness can be reused/repinned in the car to work with this?
Old 03-05-2016, 05:57 AM
BOTTLEDZ28's Avatar
Transmission: A4
I'm sure you could reuse the factory harness and just repin it. It may require some tweaks here and there though.
Old 03-05-2016, 06:00 AM
BOTTLEDZ28's Avatar
Transmission: A4
Yes it replaces the stock ECM under the dash. It does not use Proms. It uses a hard drive that can be rewritten using a laptop and a cable provided. You have ability to load different pre programmed tunes in by using the laptop. Street tune, race tune, nitrous tune. Etc
Old 04-06-2016, 07:54 PM
BOTTLEDZ28's Avatar
Transmission: A4
ttt
