[VA] Tpis Mini Ram intake
Car: 92 Z/28...many more !
Engine: LY6 / pro charger
Transmission: 4L70E 5000 stall
Axle/Gears: Moser 9" 3.89 gear
I have a Tpis Mini Ram intake ( port matched to 1206 ) fuel rails 48# injectors with an 58MM valve body will sell all together or part. Ran on dyno only in like new condition $1000 for all!
The TPiS MiniRam is the ultimate small block Chevy fuel injection manifold for both road and track. The TPI style intake works excellent at creating a large amount of torque at low RPM, but rapidly drops off as the revs rise. The TPiS MiniRam produces an ultra flat torque curve and builds incredible amounts of horsepower, pulling strong to 7500 RPM through it's specifically designed plenum and runners. The MiniRam can deliver as much as 80hp or more over a stock TPI intake, depending on the engine combination. It is also a great and simple way to convert any small block Chevy to fuel injection. The MiniRam's one piece design makes for a clean, uncluttered installation that is easy to work on while eliminating the possibility of vacuum leaks that multi-piece manifolds tend to experience. The casting is shot peened for an even texture and the ports are sized for a 1206 intake gasket. Sitting 2" shorter than a TPI system the MiniRam has plenty of hood clearance and is a perfect choice for a hot rod application. Intake comes with stainless steel intake bolts and washers, throttle brackets, waterneck, MAT sensor relocation kit. Will need to use the TPiS fuel rail kit. Please specify Corvette, F-Body, or retro-fit.
Re: Tpis Mini Ram intake
it is the 1206 mini ram I ran this on dyno only its in new condition $1000
the mini ram is available it IS 1206
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
how much for the mini ram minus the injectors and throttle body? thanks
SUPER CHEVY66
22
03-06-2016 01:29 PM
82z28man
LSX and LTX Parts
01-24-2016 07:15 PM
82z28man
01-16-2016 12:57 PM
