[Sold] BMR 700r4 trans crossmember $125
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
Have a new BMR crossmember that was installed in my car and then uninstalled when I realized it was the wrong crossmember. I already had a tubular torque arm and this one requires you use a BMR torque arm. Oh well up for grabs, bought for $260 - need it gone $125
http://www.hawksthirdgenparts.com/ca...t-application/
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
Re: UMI T5/700r4 trans crossmember for torque arm relocation
How does it require you to use a UMI torque arm? I thought you could use any of them with this? That's what it says on their site for 2228...
Q: Which brand torque arms will this work with?
A: This set-up will work with virtually any torque arm on the market as long as it bolts into the stock location. It will also work excellent with the stock torque arm when using a 1-piece bushing (item #3004).
Deleted as crossmember is BMR not UMI
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
How much for shipping to Massachusetts 02019?
Let me check it out tomorrow night
Looks like fedex estimates $16 to ship ground to you
Yes the crossmember is still available
My appologies, I got my info screwed up. I replaced this unit with a UMI crossmember. This is the BMR crossmember that requires their torque arm http://www.hawksthirdgenparts.com/ca...t-application/
Sorry for the confusion. Changing the original post to note this
Re: BMR 700r4 trans crossmember for torque arm relocation
Would like to move this thing on, will accept reasonable offers. Keep in mind ground shipping with this size is $20-50
Still available - make an offer
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
Re: BMR 700r4 trans crossmember NEW make offer
Still available? What Transmission is it for?
How much shipped to 78834
Re: BMR 700r4 trans crossmember $125
Its for a 700r4. I have a pontential buyer this weekend. If that falls thru I will note on here
Fireball
04-29-2016 12:15 PM
84strokerbird
02-26-2016 07:15 AM
Rob's z-28
02-21-2016 01:32 PM
