19 tooth driven gear (white) T5 elect speedo
Car: 1987 Trans Am
Engine: 355 Edel Int, SLP, Edel heders 8PSI
Axle/Gears: 3.45 Borg Warner
I found a T5 in the junkyard mated to a V6 but had the electronic speedo. I grabbed the little speedo driven gear off of the sending unit because they are a nightmare to find. This one is white with 19 teeth. I'll take a pic and double check tooth count(it was getting dark). Not even sure what it's worth...
Car: 1987 Trans Am
Re: 19 tooth driven gear (white) T5 elect speedo
Well, anyway...i'm gonna start collecting these as i see them in the junkyard. i'll report what kind as i collect them. maybe i'll just grab the entire VSS senders also.
