[KY] World Class T5 from '88 Camaro. $600/offer
Has bellhousing, pedals, shifter, flywheel and clutch. I thought I had the clutch fork but I'll have to look for it. $600/offer
Car: 87 RS Camaro
Engine: LS6
Transmission: Tremec 6 Speed
Axle/Gears: FAB 9, Floater, 370 True Trac
Re: World Class T5 from '88 Camaro. $600/offer
Can you explain what is so World Class about it?
Car: 1991 Z28
Transmission: WCT5
Axle/Gears: Positive 4.10
I was told by AAMCO that the world class version of the T5 is a stronger transmission. hope this helps and again it is what I was told when faced replacing the tranny or rebuilding mine which is the "world class" version. I opted for rebuilding mine and sold the other one which turned out to be a non world class.
Car: '02 T/A
Transmission: 4l60e
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
A world class t5 has roller sleeves under the gears on the mainshaft as opposed to bushings, and the countershaft has tapered roller bearings on either end which counteract the natural thrust of the gears in action a lot better. These transmissions have a higher torque rating than non world class t5s.
will899
11-01-2003 01:47 AM
