[MN] 358 DART LITTLE M BUILT W/ FORGED CRANK N PISTONS, BILLET RODS. NEW NEVER BEEN RUN
Car: 1986 irocz
Engine: 358dart worldheadsprochargerfastxfi
Transmission: 700r4 1800 stall tci and b&m everyt
Axle/Gears: posi 2.73 highway gears
8,000.00 OR BEST OFFER PLUS SHIPPING AND PLUS PAYPAL FEES .
9 TO 1 COMPRESSION RATIO BUILT TO LAST FOR SUPERCHARGER PROCHARGER TURBO NITROUS
PRICES LISTED ARE WHAT I PAID NOT WHAT I EXPECT TO GET
WOULD LIKE TO SELL COMPLETE BUT MAY DISASSEMBLE IN FUTURE.
I have an accel street ram intake that goes with this if interested see other listing.
MAKE AN OFFER ON WHAT YOUR INTERESTED IN AND IF I DISASSEMBLE PARTS WILL GO TO THOSE WHO CONTACT ME FIRST, WITH A REASONABLE OFFER OF COURSE.
FEEL FREE TO ASK ANY ?'S
ENGINE BLOCK: $3,300.00
MACHINE SHOP COSTS & PARTS $1,500.00
TOTAL $4,800.00
PART # 31131111
DART LITTLE M
DART LITTLE M BLOCK BILLET STEEL 4 BOLT MAIN CAPS AT ALL 5 LOCATIONS WITH ARP PRO SERIES BOLTS.
PRESSURE CHECKED.
BORED TO 4.030” +/- .0002” CAN BE BORED TO 4.125” HAS SIAMESE CYLINDER BORES.
TRUE DECKED ALIGNED WITH CRANK BORE, FINISHED SMOOTH FOR MULTI LAYER STEEL HEAD GASKETS
BORED AND HONED WITH TORQUE PLATES, WATER PUMP, MOTOR MOUNTS, JESEL BELT DRIVE PLATE, BELLHOUSING INSTALLED ON BLOCK AND
HONED WITH HOT WATER (180 DEGREES F) BEING PUMPED THROUGH THE BLOCK.
LIFTER BORES HONED.
DEBURRED ALL SURFACES, PRIMED GRAY, PAINTED 2 COATS CAST ALUMINUM, 2 COATS CLEAR, ALL HIGH QAULITY ENGINE PAINT WITH CERAMIC.
OIL GALLEY PIPE PLUGS INSTALLED WITH PROPER SIZED HOLES DRILLED IN THEM AS PER DARTS RECCOMENDATION.
CHAMFERED / GROUND DISTRIBUTOR HOLE FOR USE WITH O-RINGS ON DISTRIBUTOR.
FEL PRO MULTI LAYER STEEL HEAD GASKETS, FEL PRO FLOUROELASTOMER/ VITON CRANK SEAL, FEL PRO 1 PIECE SILICON OIL PAN GASKET, FELPRO REUSEABLE PLASTIC WITH VITON SEAL THERMOSTAT GASKET, FEL PRO TIMING COVER AND WATER PUMP GASKETS. (THE BEST GASKETS/SEALS AVAILABLE)
12 POINT HEAD STUDS
BILLET ALUMINUM OIL FILTER MOUNT WITH NO BYPASS.
CVR CNC MACHINED FUEL PUMP BLOCK OFF RED ANODIZED
ALL ACCESSORY BOLTS ARE ALLEN HEAD STAINLESS STEEL
USED THE DART BLOCK FINISHING KIT (COATED CAM BEARINGS, TIMING DOWELS, FREEZE PLUGS, ETC.)
SEALED POWER COMPETITION ROD AND MAIN JOURNAL BEARINGS.
HAS NEW URETHANE MOTOR MOUNTS INSTALLED ON CAR.
THIS BLOCK IS A MONSTER NOT THE LIGHTWEIGHT SHP VERSION.
CRANKSHAFT: $1,430.00
PART #353557-4
COMPETITION PRODUCTS, HOWARDS / CALLIES PROMAX
CERTIFIED 4340 AIRCRAFT GRADE STEEL. NO TWIST FORGING (MADE BY CALLIES) HAS BIG BLOCK CHEVY SNOUT DIMENSIONS AND DUAL KEYWAYS ONE IS STANDARD SMALL BLOCK AND OTHER IS 0.250” ALSO USES BIG BLOCK DAMPER BOLT. (MUCH STRONGER FOR SUPERCHARGER USE) MADE IN USA.
CAN USE 5.7” CONNECTING RODS
3.500” STROKE STANDARD 350 MAIN JOURNALS AND .125” FILLETS, 1” ANGALITE LIGHTENING HOLES ON ALL THROWS. PERMATOUGHED AT CALLIES TO A DEPTH OF GREATER THAN .080” SO CAN BE REGROUND MANY TIMES WITHOUT HAVING TO GET HARDENED AGAIN.
ROUNDNESS HELD TO WITHIN 60 MILLIONTHS OF AN INCH AND TAPER HELD TO WITHIN .0003”. SURFACES FINISHED TO 5 MICRONS OR BETTER
INTERNALLY BALANCED, COUNTER WEIGHTS TURNED DOWN AND MALLORY METAL SLUG ADDED
MONSTER CRANKSHAFT ONE OF THE BEST AVAILABLE
CONNECTING RODS: $900.00
PART # BR6000
COMPETITION PRODUCTS / HOWARDS – CARILLO
6.00” ULTIMATE DUTY BILLET STEEL RODS CERTIFIED 4340 AIRCRAFT GRADE STEEL MADE IN USA.
DOUBLE RIBBED CAPS, PROFILED FOR STROKER CLEARANCE, MULTI PHASE HEAT TREATED, POLISHED THEN SHOT PEENED AND STRESS RELIEVED, AMPCO BRONZE BUSHINGS AND CAP ALIGNMENT DOWELS, ARP 2000 SERIES ROD BOLTS.
BIG ENDS SIZED AT MACHINE SHOP FOR PERFECT OIL CLEARANCE
BALANCED
ABLE TO SUPPORT 1,OOO+ HP
PISTONS: $783.00
PART # SBC250030i20
MAHLE POWERPAK COATED
-20 CC D SHAPED DISH, FORGED
MAHLE 1.5 MM – 1.5MM – 3.0 MM RINGS (LOW DRAG = FREE POWER) FILED TO FIT AT MACHINE SHOP.
3.500” STROKE AND 6” CONNECTING ROD
ENTIRE PISTON IS COATED, GRAFAL ON SKIRTS, GREY HIGH TEMP PHOSPHATE COATING ON REST.
MAHLE PISTON PINS. BALANCED. ROUND WIRE PIN LOCKS.
TIMING SET: $1,200.00
PART # KBD-31200
JESEL BELT DRIVE
SMALL BLOCK WITH BIG BLOCK CRANK SNOUT.
RUNS DRY / NO OIL
2 PIECE ADJUSTABLE UPPER PULLEY (THE GOOD ONE) CAN ADJUST TIMING UP TO 10 DEGREES ADVANCE OR 10 DEGREES RETARDED.
HAVE 2 CAM ADAPTERS FOR FLAT TAPPET AND ROLLER CAM (NEW)
NEW TEFLON JESEL SEALS INSTALLED FOR CRANK AND CAM
NEW BELT
NEW CRANK PULLEY AND OLD CRANK PULLEY (WAS USABLE BUT SHOWED SOME WEAR SO I GOT NEW ONE)
2 PIECE ALUMINUM JESEL BELT DRIVE COVER, CAN ADJUST OR REMOVE CAM WITHOUT HAVING TO LOOSEN OIL PAN OR REMOVE HARMONIC DAMPER OR CRANK PULLEY, JUST REMOVE WATER PUMP AND 2 TIMING COVER BOLTS.
HAVE EXTRA CAM THRUST SHIMS, CAM INSTALL TOOL
ALUMINUM PLATE AND COVER WERE BEAD BLASTED AND PAINTED WITH CLEAR ENGINE PAINT
ARP BOLTS AND STAINLESS ALLEN HEAD COVER BOLTS AND WASHERS.
DAMPER: $425.00
PART # 917783
ATI 7.25” SUPER DAMPER SMALL BLOCK CHEVY WITH BIG BLOCK CRANK SNOUT.
SFI APPROVED
INTERNAL BALANCE
WAS INSTALLED ON CRANK DURING BALANCE JOB WITH
BIG BLOCK CHEVY BOLT
BILLET ALUMINUM ADJUSTABLE TIMING POINTER $25.00
SFI APPROVED EXTREME DUTY FLEXPLATE $100.00
VERY THICK WITH FULLY WELDED RING GEAR
WAS INSTALLED ON CRANK DURING BALANCE JOB.
LIFTERS: $370.00
PART # 91164
HOWARDS RETRO FIT HYDRAULIC ROLLER LIFTERS (TALL BODY)
6500 TO 7000 RPM
THERE IS A REV KIT AVAILABLE FOR THESE LIFTERS ALSO. (IF YOU WANT MORE RPM)
CAMSHAFT: $320.00
PART # 07-305-8
GRIND # LT1 276HR-14
COMP CAMS HYDRAULIC ROLLER CAM
XTREME ENERGY 276HR-14
220* INTAKE 230* EXHAUST @.050”
276* INTAKE 290* EXHAUST @.006”
110* INTAKE CENTERLINE
LOBE SEPERATION 114*
LOBE LIFT .340”
LIFT WITH 1.6 RATIO ROCKERS .544”
1,500 TO 5,800 RPM RANGE WITHOUT SUPERCHARGER
1,500 TO 6,800 RPM RANGE WUTH SUPERCHARGER
WAS DEGREED AND INSTALLED STRAIGHT UP TO ACHIEVE THIS REQUIRED 1* RETARD,
COMP CAMS RECCOMENDED CAM.
ROLLER ROCKER ARMS: $200.00
STAINLESS STEEL 1.6 RATIO
7/16” SCREW IN STUDS
TALL ADJUSTER NUTS FOR USE WITH STUD GIRDLE IF DESIRED
OIL PUMP: $120.00 + $35.00 (PICKUP) + $20.00 (STUD, BAFFLE) + $100.00 (OIL PAN) $275.00 TOTAL
PART # 10552
MELLING SELECT +10 PERCENT VOLUME (HIGH PERFORMANCE PUMP)
ALLEN KEY PRESSURE ADJUSTMENT, BLACK OXIDE COATED, BOLT ON .750” PICK UP (NORMAL IS .625”) GEARS ARE DOWELED ON BOTH ENDS. BLUEPRINTED.
1 PIECE STEEL DRIVE SHAFT
ARP 12 POINT MOUNTING STUD
MOROSO ANTI SLOSH BAFFLE AND STOCK APPEARING GOLD IRRIDATED PAN WITH WINDAGE TRAY AND TRAP DOORS FOR OIL CONTROL (PAINTED CLEAR).
CYLINDER HEADS: $1,400.00 W/PARTS AND PORT WORK
PART # 042750 $670.00 BARE W/ NO PORT WORK
MOROSO VALVE COVERS 175.00 CAST ALUMINUM POLISHED 2 BREATHER HOLES IN EACH
WORLD CAST IRON (9 TO 1 COMPRESSION RATIO) 1.94” X 1.5” VALVES
60.5 CC COMBUSTION CHAMBERS ALL CC VOLUME MATCHED, PORTED AND BOWL JOB, VALVES UNSHROUDED AND POLISHED.
PORTED AND POLISHED AND MATCHED INTAKE AND EXHAUST RUNNERS.
INTAKE PORT ENTRY PORTED TO FEL PRO 1205 GASKET TRIMMED OPEN TO BLUE SILICONE SEAL (SAME AS INTAKE MANIFOLD).
7/16” ROCKER STUDS
CENTER OR PERIMITER BOLT VALVE COVERS CAN BE USED.
HAVE MOROSO POLISHED ALUMINUM CENTERBOLT COVERS INSTALLED. (2 HOLES IN EACH VALVE COVER) WITH GROMMETS AND BAFFLES AND K&N BREATHER AND OIL FILL PLUG FOR ANY SET UP WITH OR WITHOUT PCV VALVE.
ULTIMATE DUTY 1.25” HYDRALIC ROLLER VALVE SPRINGS. INSTALLED AT 1.78” 140 LBS SEAT PRESSURE.
CAN USE 1.43” VALVSPRINGS WITHOUT MACHINING SPRING PADS.
VTO CHROMEMOLY RETAINERS
VTO VITON VALVE STEM SEALS
-.030” INSTALLED HEIGHT VALVE LOCKS
STAINLESS STEEL 1.94” INTAKE AND 1.5” EXHAUST RACE VALVES UNDERCUT / PROFLO ,NECKED DOWN. MADE IN USA.
VALVES FULLY LAPPED TO SEATS.
STAINESS STEEL FULL ROLLER ROCKER ARMS 1.6 RATIO, 7/16” STUDS WITH LONG BODY ADJUSTER NUTS READY FOR STUD GIRDLE IF DESIRED.
12 POINT HEAD STUDS
LOCKING HEADER BOLTS
FEL PRO SILICONE CENTERBOLT GASKETS
EXTRA SET OF FEL PRO INTAKE GASKETS
MR. GASKET COPPER HEADER GASKETS 2 SETS
TOTAL $4,800.00
PART # 31131111
DART LITTLE M
PRESSURE CHECKED.
LIFTER BORES HONED.
12 POINT HEAD STUDS
PART #353557-4
PART # BR6000
BALANCED
PISTONS: $783.00
PART # SBC250030i20
PART # KBD-31200
JESEL BELT DRIVE
RUNS DRY / NO OIL
NEW BELT
DAMPER: $425.00
PART # 917783
SFI APPROVED
INTERNAL BALANCE
LIFTERS: $370.00
PART # 91164
6500 TO 7000 RPM
CAMSHAFT: $320.00
PART # 07-305-8
LOBE LIFT .340”
PART # 10552
7/16” ROCKER STUDS
12 POINT HEAD STUDS
Car: 1986 irocz
Re: 358 DART LITTLE M BUILT W/ FORGED CRANK N PISTONS, BILLET RODS. NEW NEVER BEEN RU
TTT
Car: 1986 irocz
ttt
Car: 1986 irocz
you are in netherlands?
Car: 1986 irocz
yes i am familiar with shipping containers and their cost. i have sent 2 containers to other side of the globe myself.
if you are serious pm me.
Car: 1986 irocz
ADDED PICTURES
Car: 1986 irocz
Car: 1986 irocz
price added
Car: 1986 irocz
TTT
Car: 1986 irocz
WILL NOT BE DISASSEMBLING. SELLING AS COMPLETE MOTOR.
Car: 1986 irocz
SOLD !!!!!!!!!!!!!!!!
