[KS] 3.1L Related Parts
3.1L Related Parts
Update 10/14/16: I crushed most of this stuff this morning. Thanks for looking!
I'm parting out a locked up 1991 3.1L V6. There's the engine that should be good for a core or rebuilder, all the related parts - distributor, injectors, intakes, exhaust manifolds, serpentine pulleys, electronic EGR, starter, etc. Also have the V6 700R4 that's gotta go. I got the car non-op so I have zero insight to how anything worked, so your chances are the same as parts from the U-Pull-It yard.
Private Message me with what you need and your offer.
Re: 3.1L Related Parts
-Bump-
Plenty of parts on this car that I'm not using...
Radiator, 16" electric fan with upper and lower mounts, air cleaner assembly, engine, 700R4, 10-bolt 3.23 drum rear, full 3.1L exhaust. I'm also not using the steering box, coil springs, front and rear sway bars, spindles, front brakes, brake lines, fuel lines, 15x7" 20-slot wheels, 120mph gauge cluster, etc
-Bump-
4spd auto shifter, automatic brake pedal assembly, heater core hard lines, engine fuel lines, throttle cable, etc are all off the car and available.
Collect them ALL! Only you can save these fine pieces of base model hardware from an unfortunate end in a sanitation truck.
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
I'll take the harmonic balancer if you still have the 3.1L engine????
Sheet dawg, I dumped that thing in a pile of scrap steel at the recycler's like, six MONTHS ago! I've still got the distributor, fuel rail, and fuel hard lines... Pretty sure everything else is probably already melted down and on it's way to China by now.
92rszz4
08-07-2016 10:49 AM
89irocz355
06-06-2016 10:52 AM
