High Flow TPI Manifold, Custom Runners For Sale
Car: 63' Acadian
Engine: 355ci
****SOLD****
SELLING IT!
Well, Its been fun. But I am moving on to bigger and badder things. So I am selling this Custom high Flow set up. I am selling:
- The lower intake (edlebrock 3817, Vortec base), with billet egr block off plate
- My Custom built high flow runners https://www.thirdgen.org/forums/tpi/...w-runners.html
- Stock rails with Holley adjustable regulator and -06 AN adapters
- The heavily ported upper plenum and aluminum distributor cover
- 58mm twin blade billet throttle body with modded IAC housing (no coolant passage)
- IAC, TPS, MAT, MAP sensors, stainless hardware and Chrome thermostat housing
If I didn't list it, then its not included.
$750 USD Plus shipping.
SELLING IT!
Re: High Flow TPI Manifold, Custom Runners For Sale
subd-
I have a similar setup
1 Post
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
Is the lower ported? What year is the plenumn and TB setup for?
Car: 63' Acadian
Engine: 355ci
I port matched the lower to the runners. The TB is using the early throttle linkage, but I have the adapters to convert it to the late linkage.
The plenum was originally from an 86', but I was running speed density and I deleted the 9th injector.
BK
Aftermarket Product Review
10-06-2000 04:40 PM
