NOS sensors, 85-89 BBK throttle body,Edelbrock Intake manifold, misc tpi parts.
Old 09-19-2016, 09:41 PM
Bald_eagle_machine's Avatar
Car: 2011 Camaro 2SSRS w/ Procharger
Engine: 6.2 LS3
Transmission: M6 TR6060
Axle/Gears: 3.45
I have a bunch of stuff up for grabs. Prices are pretty firm, everything is a good value, and shipping is included in the lower 48. So please no low *****.
NOS 85-89 TPI 305 knock sensor- $30 this was $60 new
NOS 85-89 TPI TPS(throttle position sensor)- $50 this was $94 new
Refurbished 85-89 BBK 52mm throttle body. New gaskets all the way around. With no tps $120 firm if you would like it with the new TPS I'll make it $150 firm Saving you on the sensor.
Top end freshen up kit. (Only selling as a kit.) Fel Pro centerbolt valve cover gaskets, Fel Pro Viton seals, and comp cams valve Springs. Perfect to refresh your leaky valve seals. $100
Edelbrock performer eps manifold casting 2701. Comes as you see it. Fresh paint job, chrome water neck, chrome 3in pan filter, and carb studs. $75.
Old 09-19-2016, 09:45 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Re: NOS sensors, 85-89 BBK throttle body,Edelbrock Intake manifold, misc tpi parts.
Valve spring tolerances.
Valve seal and spring kit, with valve cover gaskets.
Bbk throttle body.
Throttle body butterflies
Old 09-19-2016, 09:47 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Knock sensor
TPS sensor
Old 09-22-2016, 09:38 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump
Old 09-25-2016, 07:31 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump
Old 09-27-2016, 07:44 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump, prices updated
Old 10-07-2016, 04:46 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump, make me an offer.
Old 10-12-2016, 10:28 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Prices lowered for the last time. Prices are very fair, and very firm. Will take trades for some stuff. If you have something I'd like we could make a deal.
Old 10-17-2016, 06:02 AM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
I'm interested in the throttle body. I have a BBK 58MM that has a vac leak at the throttle shaft, which is pissing me off. I don't know if it's a problem in general with BBK, or just I got an unlucky one.
How is this one?
-- Joe
Old 10-17-2016, 11:43 AM
Engine: 6.2 LS3
Axle/Gears: 3.45
I bought this from a part out on a running car. So as far as I know, it's in good shape. I replaced all the gaskets, and cleaned everything up. Should run nice and smooth. As stated it is just the throttle body. No iacv, or TPS sensor. Unless you would like to pay the extra for the nos one I have
Old 10-17-2016, 12:07 PM
anesthes's Avatar
I ended up getting one this afternoon, thanks though. Good luck with the sale.
-- Joe
Old 10-26-2016, 11:25 PM
Engine: 6.2 LS3
Axle/Gears: 3.45
Bump
WIll36
09-11-2016 05:32 PM
87zz28
08-29-2016 12:38 PM
Bald_eagle_machine
08-27-2016 10:24 PM
kg1922001
08-25-2016 09:06 AM
RunawayRadio
08-23-2016 07:26 PM
Quick Reply: NOS sensors, 85-89 BBK throttle body,Edelbrock Intake manifold, misc tpi parts.
