[OH] F.A.S.T. Classic ECU
Old 09-24-2016, 06:14 AM
wadsfootball's Avatar
Fast Classic ecu and harness for TPI for sale. Bought this used back in the spring time and ended up never installing it and lost interest. 400$
Old 10-31-2016, 06:40 PM
Re: F.A.S.T. Classic ECU
TTT
Old 11-02-2016, 07:36 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Hi, is this the self-learning ecu platform?
thanks, Greg
Old 11-02-2016, 07:01 PM
No it is not self learning.
Old 11-02-2016, 07:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
FAST will help you out with a base tune based off of the mods done to the car. That system was actually mine. I bought it brand new from a local Holley/FAST dealer. I gave FAST a call and told them what engine and mods I had and they got me set up so that I could at least start the car and make sure everything was working correctly.
Old 11-05-2016, 04:15 AM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
So here comes the question. What all is needed for this to go into my '85 T/A? I see a harness there. I want to boost later down the road.
My thing is that if I upgrade from my 85 ecu to something new I am sure this is already ahead of the older GM units.
Old 11-07-2016, 07:41 PM
I believe everything is there to make it work in a 3rd gen. It has a harness made for the tpi motor. Uses a MAP sensor. Boost should not be an issue.
Old 11-09-2016, 02:16 AM
HellHound's Avatar
Sending pm
FormulasOnly
09-26-2016 06:21 AM
Tibo
09-14-2016 08:19 PM
berlinetta9
09-06-2016 06:52 AM
Ryan-87GTA
Car Audio
09-04-2016 09:58 PM
IrocJoeCool
09-01-2016 12:48 PM
Quick Reply: [OH] F.A.S.T. Classic ECU
