[PA] Flywheel for V6
1 Post
Car: 90' Firebird
Engine: 3.1
Axle/Gears: 3.27 9-Bolt
Flywheel for V6
Doing a AT to manual conversion and I need a good flywheel. (V6 car)
I'm in PA but small enough that shipping isn't an issue.
Thanks guys
PS if anyone had a new or like new clutch and pressure plate setup they didn't end up using I'm up for that as well...
Thanks guys
Car: Too many!
Re: Flywheel for V6
Where in PA? I'm near Boyertown. I have a lead on an 85 Firebird v6 manual trans car that was wrecked. If you are interested let me know, I'd consider buying it to part out like I've been debating all these years lol. Thanks!
1 Post
Car: 90' Firebird
Engine: 3.1
Re: Flywheel for V6
Everything I'm reading it looks like they are the same 2.8 and 3.1
Can anyone help me out? I want to get rolling this weekend...
Re: Flywheel for V6
I'm sure you checked,.... you should double check;
From another thread on this topic:
I don't write wanted adds unless I NEED something:
https://www.thirdgen.org/forums/engi...-flywheel.html
I re-used the Flywheel from the original 87 MPFI when I swapped the 3.1 in it's place. Everything else from the 3.1 swapped without a problem !! Boy; does that engine vibrate when the wrong flywheel is installed !!
The 3.1 Flywheel has a neutral balance. it's the same flywheel from the 91 3.1 to the 94 3.4 from what I've read.
Since writing this message I have picked up a 3.4 V6 Flywheel,....... Thanx for the reply !!
Car: Too many!
Re: Flywheel for V6
Unless some odd miracle happens I probably wont have a 90-94 parts car by the weekend. I could possibly get you a new GM one though or check with one of the other parts guys I work with to see if they could get one. If you are interested shoot me an email with your # my email is wwe442@aim.com. Might be able to work some sort of magic for you but no guarantees.
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
Re: Flywheel for V6
I have a flywheel from my '92 3.1 in my garage. If you pay shipping I can send it to you from Montana 59102.....I don't even want anything for it
Re: Flywheel for V6
pm sent
monte87cortez
09-26-2015 08:10 PM
el_muerte
09-16-2015 12:01 AM
