[OH] WTB: Exhaust manifolds from a 88-92 tbi 305.
Want a title? Post!
I`m looking for a set of stock exhaust manifolds from a third gen 305 tbi. I`ve been looking for a set for a project that I have in the works, and have as of yet come up wanting. This is for a right hand drive project, so headers won`t agree with the steering shaft. For frame clearance, I specifically need the manifolds from a low power tbi, which have the shorter neck on the right side.
Here`s hoping that someone here has replaced a set and have the originals sitting around.
Cheers! And Thanks!
Cheers! And Thanks!
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: WTB: Exhaust manifolds from a 88-92 tbi 305.
I've got a set off a low hp lb9. Not sure off hand if they're the same as tbi. $25 + ship
Want a title? Post!
Thanks, but those aren't quite the same as the tbi manifolds. The tbi manifolds have a shorter neck and slightly different flange angle on the right side.
But, again, thanks anyway.
Here's a pic of the style I'm looking for:
Car: 2011 Camaro 2SSRS w/ Procharger
Engine: 6.2 LS3
Transmission: M6 TR6060
Axle/Gears: 3.45
I have a 1991 camaro rs tbi, that I'm parting out. Has original exhaust manifolds.
Yup,... I do have a set. Driver side studs were removed - pass side studs need to be removed. O2 sensor and Air Tubes in good shape.
Not sure if they were fromaCarb or TPI car,... but they are not the TPI version. Here is a pic showing the TPI manifold below the TBI/Carb type.
Manifolds are $50 and shipping to ZIP = $45. Send me a PM if your seriously interested.
Car: 1992 Z28
Engine: 5.7L LS6
I should have a set from a 1992 rs if you still need them.
I am in Ohio also 44270.
transaero
08-31-2015 01:14 AM
