[CA] 90-91 V-8 TPI Memcal
Old 11-25-2015, 01:06 AM
Dr.E's Avatar
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
Need V-8 $8D memcal for 1227730 /1227727 ecu preferably with netres/knockboard to most closely support 383 ie OEM 5.7l with auto trans OEM BCC ie, AXCS, ANHT, AUJP ,ANJF,
not sure if the manual trans BINS will have same Netres or not would like to have LHM if possible. Also open to suggestions from DIY Prom guys.
Old 11-26-2015, 11:14 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: 90-91 V-8 TPI Memcal
I have one from a 91 z28 305 tpi automatic
Old 11-26-2015, 11:51 PM
Dr.E's Avatar
Car: 5500lb Brick
I'm looking for one out of a 350 TPI so, if ever needed, LHM (LIMP HOME MODE)
will work,and the 350 Knock board will work with the 350 knock sensor.
Thanks for the reply!
Old 11-27-2015, 10:48 PM
Mike 92LX's Avatar
I have one from a 91 Vette and a 90 IROC 350...
Old 11-29-2015, 11:04 AM
Dr.E's Avatar
Car: 5500lb Brick
Thank you Mike 92LX ! I PM'ed you for details.
Old 12-18-2015, 02:17 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I have 2 AUJP memcals, if you are still looking.
Old 12-18-2015, 06:09 PM
Dr.E's Avatar
Car: 5500lb Brick
Thanks, I bought a couple already. I'm sure more members have been the victim of the v-6
memcal swap and will be needing your help. I don't want to hoard and make it more difficult for the next guy to find one.
Old 12-28-2015, 06:13 PM
Want a title? Post!
delsda48's Avatar
Are the memcals still available? If so how much do you want for them?
Old 12-30-2015, 03:32 PM
Chas91Z28's Avatar
Car: 1991 Z28
I also have the memcal and the ECM from a 1991 Z28 350 - PM me if interested? I also have a memcal from a 1986 Firebird.
zdh4534
09-24-2003 02:52 PM
I8AStang
03-24-2002 11:43 PM
Quick Reply: [CA] 90-91 V-8 TPI Memcal
