[MO] Steering Components Needed!
Old 10-20-2016, 03:43 PM
Want a title? Post!
powderedwater67's Avatar
Car: 1992 Firebird Base
Engine: LH0 3.1L V6 191 CI
Transmission: TH700-R4 4-Speed Automatic
Axle/Gears: Stock
In short, I need a complete steering setup for my 92 Firebird base 3.1L V6. MOST IMPORTANTLY, I need the standard steering setup with the 3 & 1/2 turn ratio, NOT the 2 & 1/2 turn sport version. My RPO codes say it's supposed to have Soft Ride suspension if that helps. I need everything from the wheel to the steering box, but I'll take what I can get.
What I need:
Steering Wheel, 4 spoke airbag version with horn buttons (89-92 will work i think).
Steering Column with all the levers, rods and wiring for brights/signal/wipers/cruise/tilt/airbag etc. My car's supposed to have all those things. I'm not sure if it's supposed to have intermittent wipers though. My wipers run slow as heck despite having replaced the wiper motor. I could use some advice on that if anyone knows whats up.
The main steering shaft that comes from the wheel and column. I have the intermediate shaft now thanks to user blacksunshine'91.
And the steering Gear (3 & 1/2 turn standard version).
Here's a list of my RPO codes and options if it better helps anyone find what I need.
RPO CODES:
AAA : 4-WAY MANUAL SEAT ADJUSTER
AJ3 : RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, ALL DOORS
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
B84 : ORNAMENTATION, EXTR MLDG, BODY SIDE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DG7 : MIRROR O/S, LH & RH, REM CONT, ELEC, PAINTED
D3V : GEAR, SPEEDO DRIVEN
D8N : SENSOR, VEH SPD
D80 : SPOILER, RR END PNL
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE1 : SUSPENSION SYSTEM, SOFT RIDE
GU5 : AXLE REAR, 3.23 RATIO
IPC : TRIM-INTERIOR DESIGN
J41 : BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K60 : GENERATOR, 100 AMP
LH0 : ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
N36 : STEERING WHEEL, 4 SPOKES, SPORT
QPH : TIRE ALL, P215/65R15/N BL R/PE ST TL AL2
R8I : CONTROL, SALES ITEM NO. 59
T96 : FOG LAMPS - FRONT
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS, CLOCK, ETR
UQ1 : RADIO PROVISIONS, FOR STEREO
U62 : SPEAKER SYSTEM, DUAL COAXIAL
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
W68 : MERCHANDISED PKG, FIREBIRD, SPORT APPEARANCE
1SC : OPTION PACKAGE 03
1SZ : DISCOUNT, OPTION PACKAGE
18P : WHEEL COLOR, CHARCOAL MET (91)
45Q : MOLDING COLOR, MED GREEN MET (91)
45U : PRIMARY COLOR, EXTERIOR, MED GREEN MET (91)
6XS : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
64C : TRIM COMBINATION, CLOTH, LT BEIGE (C) (92)
64I : INTERIOR TRIM, LIGHT BEIGE (I) (92)
649 : SEAT BELT COLOR, LIGHT BEIGE (9) (92)
7XS : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8UY : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
9UY : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Link to my thread about this cars restoration: https://www.thirdgen.org/forums/memb...-firebird.html
Old 10-21-2016, 11:29 AM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
Re: Steering Components Needed!
I have steering gear pm me
Old 11-28-2016, 12:20 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
PM'd you. I have the intermediate steering shaft w/joints and the bushing as well.
